Question about Nokia N95 Cellular Phone
Fail to charge
My mobile n95 8gb fail to charge. it charges up to 2 bar only. y that?
  • cell-care May 16, 2008
    MY N95 SAY THAT IT'S CHARGING BUT IT DON'T GET CHADGE AND IT GETS HOT
    Brigadier General:
  • 7,752 Answers
Main-board could be faulty , or you could try and change the battery or reflash the firmware and see if that helps it.
Posted on Mar 24, 2008
SOURCE:
How do you check the battery charger?
https://www.youtube.com/watch?v=aO4I2v3XgM0use volt meter check all batteries first, then check voltage when it is charging
Sep 16, 2015 | Health & Beauty
2000 year honda civic cigarette lighter not working
check the power in the lighter socket or the charger which is a small transformer has not failed . Try it in another car . If it works there then I would suspect a fuse for the lighter if there is no power there.. Make sure that the adaptor plug is tight as the 2 bars on the side are the earth for the adaptor and if not tight then there may be no earth . Use a flat bladed screw driver and bend the bars out a bit to increase tension in the socket.
Feb 19, 2014 | 2004 Honda Civic
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
Hi I have just been given a loan of a heartway mobility scooter. It was only used once but the lady found it to fast so it has been packed away for 2 years. I sent it off for new batteries and a service...
Willis try plugging in the charger and charging overnite tonite. In the morning check the charge and see if you get more than 3 bars. Also look at the charger light and see if it has turned green. If it is green then the lights should all be lit, if not then you could have received a bad battery. after charging all nite bring the scooter to the place that serviced it for you and have them check the batteries to make sure that they pass a load test (do not try to drive the scooter they need to check the batteries with a full charge) If the batteries check out ok then you will have to have them check the charger and replace the charger if necessary. Hope this helps you
Mar 01, 2011 | Health & Beauty
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully...
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Aug 20, 2010 | Samsung Comeback Cell Phone
My samsung cell phone gives no indication when charging so I donot know whether is charged or not.The problem is the charger or the mobile phone?It indicates only the bar which requires charging but when I...
There are 3 solutions to your problem.
1) You need to replace your phone's battery, or
2) You need to replace your charger. (If you have a car charger, try it to determine if your home charger is the problem) or
3) you need to have the charging plug on your phone repaired; it will need to be sent in for service.
Feb 01, 2010 | Samsung SCH-u340 Cellular Phone
Not holding a charge
This is not a battery problem. Some IC on the board must have blown somehow or it is a factory defect.
See a mobile repairer or retailer for necessary checks.
Wont cost much.
rate this please
May 29, 2009 | LG VX5200 Cellular Phone
Phone will not stay on
maybe your mobile battery is defected ,
Jan 14, 2009 | Motorola Mobility RAZR V3
My sidekick 2 has a white screen and just keeps vibrating everytime i try to charge it, can someone help me
Mine did that too.... I just left it over night and then it took the charge the next day. Now I have a different problem... the phone says it is charging... the battery meter flashes 1, 2 and 3 bars like it is taking a charge but it's not... now it's dead and when I plug it in the red and green phone lights on the top and bottom of the scroll wheel flash really fast but no charging ??? HELP....
Sep 01, 2007 | T-Mobile Sidekick II
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
