Question about Canon MX300 Office All-In-One Printer
Cannon mx 300 fax
How do i stop machine redialing numbers?. Sometimes you wish it to try again other times you want to stop it. Please advise. Also when i scan more than 1 page to fax it only sends first page.Please advie what to do?
email reply to [email protected]
thanking you
Brian Wenck
SOURCE:
bluegreenash
  • 661 Answers
SOURCE: Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Posted on Aug 27, 2007
mediatecar
  • 60 Answers
SOURCE: Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Posted on Jan 21, 2008
voodoomox
  • 1689 Answers
SOURCE: lost software for cannon mx
just clik on the link below to view the resources of your printer. just click on the link then choose your computer's operating system
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15601
http://www.canon.com.au/products/all_in_one_printers/all_in_one_printers/mx300.aspx
hope this helps, good luck.
Posted on Aug 17, 2008
SOURCE: Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Posted on Oct 26, 2008
SOURCE: canon pixma mx 300 won't send or receive fax
how do u fix the fax to fax and not go on auto redial
Posted on Feb 01, 2009
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
Panafax Uf 4100 not redialing
Press the following keys
Function
7
monitor key slowly 4 times
set
clear 2 times
enter 0-15 times redials......I recommend 5 redial tries
set
stop
unplug power cord and replug.
Nov 20, 2008 | Office Equipment & Supplies
Fax sending prob
Unplug the power cord for 10 seconds.
Oct 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Canon MX300 Office All-In-One Printer Logo
155 people viewed this question
Clive
Clive
old marine
old marine
Ekse
