Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
No sound through Panasonic SA-HT930 surround system
I can't get any sound through the speakers when just watching TV, I have it when watching a DVD or listening to the radio. I have cable converter box and a Sansung HDTV.
Any thtoughts?
  • smartyj May 14, 2008
    I can't get any sound through the speakers when just watching TV, I have it when watching a DVD . I have DirectTV, HD and a Sansung HDTV. This system has been hooked up and working with no problems for over a year, it all of a sudden stopped working in TV mode
    You assistance would be greatly appreciated
  • 47 Answers
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
Posted on Mar 19, 2008
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
I have a panasonic sa-ht75 surround sound system, the sound comes through when watching a dvd, but when the tv is on the sound still comes through the tv speakers.
You have probably solved this problem now, but incase you havnt, we had the same problem, the wrong lead came with ours, you need to plug the red and white into the audio out, and this should solve the problem, hope this helps
Jan 04, 2010 | Panasonic Audio Players & Recorders
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
Reciver shuts off
Check your speaker and sub connections. When they are not imputed correctly the system will shut off.
Jan 10, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT690 speakers
Actually I gave the speakers and sub away to someone who had the dvd player but did not have the speakers.
Nov 03, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Unlock DVD SA HT930
My husband just unplugged it for 30 secs then plugged it back in and it unlocked.
Apr 10, 2008 | Panasonic sa-ht930 Home Theater Audio...
No picture
on tv select corect input ok video 1 ect make sure cable out from dvd is in right spot yellow out and in the video in yellow on tv ect
Jan 24, 2008 | Panasonic sa-ht930 Home Theater Audio...
363 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
