Question about HP Photosmart 3210 Printer
Wont print in black.
Prints in other colours OK. Have tried three new cartridges. Won't print black text or lines. Problem occurred switching back and forth between fast draft mode and normal. Prints colors fine, but black text comes out thin brownish. Black items in photos are printed black, however. Swapped black cartridge, no change seen.
  • Anonymous Apr 03, 2008
    same problem black ink low replaced with hp cartridge and thin brown print no black at all. got another black cartridge and same problem printer will not align etc. hp won't help out from under warranty.
  • KLPhillips Jun 01, 2008
    same problem.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
I suggest you first verify activate a CLEAN PRINTHEAD routine from the TOOLS/MAINTENANCE menu to see if you can blow ink thru the PRINTHEAD NOZZLES. You many need to place a damp cloth under the printhead to help 'wet' the nozzle plate in an effort to remove residual black ink buildup...you can find some youtube videos on how to do this. For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
You should also check the permanent built-in PRINTHEAD electrical performance inside this legacy printer model (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges):
A. HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
1. Press * and # keys simultaneously.
2. "Enter Special Key Combo" will be displayed.
3. Press 123 to display the 'Support/Service' menu.
4. At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
5. Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
6. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
7. Select Ok. The test page prints.
8. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
B. HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
1. Turn ON the printer.
2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release both buttons.
4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
8. Select Ok. The test page prints.
9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Jul 26, 2013
    Problem Solver:
  • 8 Answers
Look at posts on "black ink problem" entered towards end of 2008.
You may have a blockage in the (remarkably lengthy) black ink feeder system: very many people, including me, have reported this problem, which clearly results from a design fault in the 3210 (which HP will not acknowledge, although they have discontinued the model).
The solution for me was to force the blockage out, a brutal, messy and time-consuming process which you will not find in the manuals, but is amongst the 9 suggestions in "black ink problem".
I've bought a Canon. Good luck.
Posted on Jan 07, 2009
    Sergeant:
    Champion:
  • 210 Answers
check the ink level of the color cartridges also. because to print in black it will use some color also.
if everything is ok try this
> unplug the usb cable from the printer
> click on "start-->control panel--> printers and faxes".
> select all the printer icons which is related to your priter and delete it.
> once that is done, plug the usb cable back to the printer.
> wait for few minutes while it installs the driver automatically.
> if done, try printing in black from varius applications like notepad, wordpad, ms word etc.
> if o go, you may have to service the unit as you have already tried with 3 different black cartridges.
thanks and regards
agnel
Posted on Mar 17, 2008
6ya staff
SOURCE:
My colour text comes out with a shadow (in a different colour) like something is out of line. Black text prints crisp and clean.
yes, it is something of line. Color text is printed by three cartridges overlapping on the page. Most printer have a setting called Calibrate. You can sometimes do it in Windows, too.
Start button--> Control panel-->devices and printers--> (right click the name of the printer--> properties--> the last tab often is calibrate.
Sep 26, 2016 | Office Equipment & Supplies
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
WONT COME OUT OF THE ALIGN CARTRAGE MODE
if the colour cartridge is empty or any of the three colour is not got printed on the allighnment page it will not comple allignment.replace the colour also or get you colour cartridge refilled.
May 06, 2009 | HP PSC 750 All-In-One InkJet Printer
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
HP Photosmart 3210 Printer Logo
251 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
