Question about Seagate (ST3160827AS) 160 GB Hard Drive
Hard drive not being recognized
Hello! I need help. I have an HP pavilion laptop with windows xp os and it is not recognizing the external hardrive. Ive been in device manager and dont get all the parition and allocation business. I have tried it in three different ports. lights are on the device. My new P.C. recognized it immediately.
It worked on my newer computer, then worked on Windows XP for a while. 2nd time a little later, same problem "USB device not recognized"!1
  • ramroot Mar 19, 2008
    Thanks, device manager just says device not recognized, and when I update driver, it says it's current.
  • kedar1jgd433 Dec 19, 2008
    My hard disk is not recognized and i have important data on that without backup please help me out.
    Guru:
  • 377 Answers
Dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Posted on Mar 18, 2008
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
http://en.kioskea.net/forum/affich-39282-xp-can-t-recognize-hard-drive-for-os-install
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
Blinking green light
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Apr 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
264 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
