Whirlpool LEW0050P Electric Dryer Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our dryer is not drying as it has in the past. Have checked the vent, drum rotation and heat, but still does not dry clothes properly. Any suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 110 Answers
  • Posted on Apr 06, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
110
Questions
0
Helped
31761
Points
314
If the vent and the heat are fine then the only other thing that could be going bad is the timer motor. The timer motor tells the dryer how long to heat the clothes.
1 Related Answer
Timon90
Timon Gr?nlund
  • 126 Answers
  • Posted on Jan 25, 2008
SOURCE: zanussi z910r electric dryer
Maybe the fan is broken. Or clogged with lint.
Whirlpool LTE6234DQ3 stacked washer-dryer
If your Whirlpool LTE6234DQ3 dryer is not drying clothes properly on the automatic/permanent press cycle, there are a few parts that may be causing the issue: Moisture Sensor: The dryer's moisture sensor detects the level of moisture in the clothes and adjusts the drying time accordingly. If the sensor is dirty or faulty, it may not be able to accurately detect the moisture level, resulting in clothes not drying properly. Try cleaning the sensor with a soft cloth and see if that resolves the issue. Thermostat: The dryer's thermostat regulates the temperature inside the drum. If the thermostat is faulty, it may not be able to regulate the temperature properly, leading to clothes not drying properly. A multimeter can be used to test the thermostat for continuity. Heating Element: The heating element is responsible for generating heat in the dryer. If the element is faulty, the dryer may not be able to generate enough heat to properly dry clothes. A multimeter can be used to test the heating element for continuity. Ventilation: Poor ventilation can also lead to clothes not drying properly. Make sure the dryer's venting system is clean and free of blockages. It is recommended to have a professional technician inspect and diagnose the issue if you are not comfortable with checking and replacing these parts yourself.
1helpful
2answers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
1helpful
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
2answers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
5helpful
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Whirlpool Dryer- Model #YLEQ5000PW0, does not get hot enough to dry clothes and makes a ckicking noice when the drum rotates. What do you think the problem is?
if you have any heat than your element is good,the reason it take's so long to dry the clothe's is due to a blockage,first you nead to look behind the dryer with out moving it to see if the vent hose is pinched off,next try running the dryer with out the vent hose hooked up,if it dry's well than you have a blockage some were between were the vent hose hook's up to the dryer and vent outside.you nead to check the roller's for the clicking noice.
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
2answers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 • Dryers
5helpful
2answers
Kenmore 70 Series Electric Dryer Won't Dry.
Your house dryer vent is clogged. There may also be lint in the internal ducts of the dryer.
Nov 26, 2007 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
