Question about Kenmore 15864/15862 Top Load Washer
Kenmore series 80, fills and agiatates, but stops before if drains and spins
Series 80, fills and agaitates, but just stops before it drains and spins, the timer stops also, is that the lid switch?
  • chicmodel Jun 24, 2008
    Hi, my Kenmore 80 series does the same thing...It goes through the wash cycle, but when it comes time to drain or spin it wont work. So the drum is just filled with sitting water. Now my mom is upstairs scooping the water out with a bowl. I was the last one 2 use the washer. I put 2 pillows in there. One pillow was fine 2 wash...but the other wasnt. It got really soaked and heavy. So heavy that on the spin cycle the drum went absolutely crazy! So I had to take out the pillow and throw it away. It was so wet and heavy there was absolutely no way for it to dry. I let the cycle continue. But as that happened I heard weird noises, then the last thing I heard was a loud click like something snapped or broke. I said uh-oh (because im only 15) and I didnt tell my mom until this morning. We checked all the wires....they're all fine and plugged in. Im really hoping that all we need is a lid switch. With gas prices and the expenses of life, the last thing we need is a new washer.... PLEASE HELP!!!!!!!!!!!!!!! Oh and Im not sure that the exact code number thingy is 15864/ 15862 because it was a "hand-me-down" from my mom's best friend. I just know that its a Kenmore 80 series. Thanks!
  • lilred22471 Jul 26, 2008
    our washer will not drain or spin either. It agitates and thelid is clicking fine. The coupler is not broken and there are no kinks or clogs in the hosees. Any other ideas?
  • 5,911 Answers
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments. Parts can be found at searspartdirect.com or repairclinic.com.
Posted on Mar 17, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore washer 80 series will not agiate
What is the model number of your unit?
Nov 25, 2012 | Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Robert Rankin
