Question about Car Audio & Video
Radio will not play in CD mode
Hi I have a apline CDA-9830 and recetly installed. When the radio is on the you can here music playing through the speakers, however when your in the CD mode you can see the CD playing by looking at the display but no music coming out of the speakers.
  • basketbal113 Jan 07, 2009
    i got a new cd player and when i listen to the regular radio....it plays on all of my speakers...but when i play a cd...my factory car speakers will not work...just my subwoofers.
  • 40 Answers
Jasson192000-O.k it sounds like your vehicle has a factory amplifier,you have the wrong remote hooked up to the amp wire.Check the wiring and change the remote to the other blue wire.Try this and let me know ,I can help. cooltek Mar,18/08
Posted on Mar 18, 2008
SOURCE:
Iphone mode
For most alpine unit there is a separate unit to control the iPhone and is very easy is just a plug and play connection. Find a compatible unit for your deck.
Nov 07, 2013 | Alpine CDA-9856 CD Player
My Apline CDA-9831 has no sound when trying to play regular store bought CD's. It dose have sound on Tuner.
Are you using an amplifier? If so, make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue (power antenna remote turn on) to turn your amplifier on. The blue wire turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
I just installed my lightly used alpine cdA 105.the radio plays on all speakers but when I try the cd or iPod it only plays on one speaker. Any thoughts.
are you using an amplifier? if so, you may be using the blue wire (antenna remote turn on) instead if the blue/white wire (amplifier remote turn on) to turn the amplifier on. the antenna remote turns off when leaving tuner mode.
Feb 15, 2011 | Alpine CDA-105Ri CD Players
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Aug 15, 2008 | Alpine CDA-9847 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Apr 29, 2007 | Alpine CDA-9833 CD Player
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
