Just hooked up machine. Placed queen size comforter and pillow cases inside and selected normal wash, high spin. For at least 20 minutes the display showed 10 mins remaining and finally, after waiting another 20 mins we opened the door to find it was still dripping wet. Is this a malfunction? Not sure if the comforter was too thick?
694 people viewed this problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (refer manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too. As long as your dry laundry weighs within the machine's capacity, it shd be fine.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Wife said she smell something, took off the front and found a broken belt. Replaced belt from Auto zone, same size and...
Can the comforter be washed in this machine or do I have to go to a laundrymat?
when i wash bedsheets my cabrio washing machine leaks water from the bottom of the machine. it does not happen when...
I was washing a queen-sized comforter and smelled a burning ''rubber''smell from the washer. Water was on the floor. I...
The belt keeps coming off the pulley and damaging the plastic case. What should I do?
