I have bad sectors in my Hard Disk
Tell me the software to remove the bad secotors clusters from harddisk
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you can't remove them..you can only run chkdsk from the windows environment..resurfacing drives is old school, and not usual for high density drives.
  • 667 Answers
If you want want, go to your command prompt. Either start, programs, accessories or start, run, cmd and hit ok. Just type chkdsk /f and the system will tell you it can't run it right now. It will ask you if you want it to run the next time your pc starts up. Just type y and hit enter. Close the window and restart your pc. If there are bad sectors though it is time to start thinking about a new hard drive.
Posted on Mar 17, 2008
    Sergeant:
  • 349 Answers
Firstly once a disk has bad sectors ,it is on the way out ,so back up your data .
if you download the disc utility from the makers website (free) for your drive , sometimes it can recover the bad sectors and the data .
it may be that you only have a couple of bad sectors, in which case,its not so much an issue ,just leave them alone, but as you get more & more the drive is on its way out .
if you have critical data on it, replace the drive now ,before you cant get into.
or you may live to regret it .
good luck
Terry
    Master:
    Sergeant:
  • 482 Answers
Try scandisk from your pc. bad secotors are a sigh that your hard drive is going out. I would not use a hard drive that reads bad secotors. scan it first with AVG
http://avg.download-go.com/ its free.
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Hi i have a problem my computer's hard disk is formatting when i format it shows the error of bad sector so please give me suggestion how can i remove bad sectors
Hi, the bad news is you cant remove the bad sectors, once you start getting these you will keep getting even more what it is telling you is that the part that stores the data on has either been damaged due to a part failing in the hard drive or it could have got knocked about a bit, the usual suspect is down to the arm that moves across the disk that reads the data these ware and then this causes it to touch the data part of the disk causing the bad sectors.
their is nothing you can do to repair the problem as its just impossible the only chance you have of using the computer is to replace the hard drive, thats your only option.
the bad sectors are telling you that that part of the hard drive is damaged and can no longer be used, the disk will work around these parts but you will find you will keep getting more and more and eventually you will lose everything on the hard drive and you wont be able to use it any more.
you need to get hold of new hard drive before you install your operating system again.
Jul 14, 2010 | Microsoft Office Professional 2007 Full...
How to remove bad sector in HDD ???
If you are a professional you can use two programs or softwares to remove bad sector from any hardware.
1. Hard Disk Regenerator
2. Spin Write
100% guaranteed it will work to repair them or some time remove bad sectors from hard disk and your hard will work so better and fast like a new hard disk.
Good Luck
Dec 16, 2009 | LaCie (300770) 250 GB Hard Drive
Bad sectors of my hard drive
There's no concrete way, you can try these software:
May 27, 2009 | Western Digital WD Passport 250GB Portable...
Boots halfway then it stops.
That is a sign of Hard Disk Failure or bad clusters due to inproper formating
Perform this tests to ascertain your Hard disk durability
1. Turn Off the computer
2. Restart it, Press F2 to go to the BIOS at the black screen when the PC comes up displaying the manufacturers name:
3. Goto the Advanced Menu or the Menu Option that displays your Drives.
4. On the drive that has the problem, select the option that performs a hard disk test.
This would take sometime and at the end, the result of the test would tell if your Hard disk is bad.
A second option is to use a reliable hard disk partition software like partition magic to reformat and repair bad clusters and damaged sectors in your harddisk
Click here to download it and use it if the first option fails:
http://www.soft32.com/Download/free-trial/Partition_Magic/4-151-1.html
May 21, 2009 | Gateway Computers & Internet
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Bad Sector on Harddisk
Set defrag to run at boot up and it will resolve any bad sectors you have, and will write a new boot registry for you.
Jul 17, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Pxe-e61 media test failure. i have managed to get the computer into safe mode but will not run in normal mode why is this and how can i fix it?
This issue is often caused by either an incorrect setting in bios or a bad boot device, such as a bad hard disk drive. To resolve this issue, run scandisk to check if the hard drive have develop a bad sector. Double click mycomputer and right click drive C: and select properties,tools,check now and check the the two options in the check this option windows and reboot your computer. During the reboot of computer the scandisk is check your harddisk after the scandisk finished scanning you can read the result if you see the bad sector or cluster found it's mean that your hard drive is damage in you need to replace it to correct the error. But if no bad sector found try to remove the software or hardware that you installed before the problem is occured go to control panel then add and remove software. if you have a registry scanner software like pctools registry mechanic try to run it to fix the problem in the registry.
Apr 16, 2008 | Computers & Internet
Harddisk fault
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Mar 03, 2008 | Compaq Presario 5000 PC Desktop
Bad sectors in hard disk
Search in google.com for program BAD SECTOR REPAIR
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
