Question about AcerPower 1000 (AP1000EA380M) PC Desktop
Usb problem I cannot use my keyboard & mouse at the begining when I'm start my computer. What is the problem?
  • 1 more comment
  • adli Mar 17, 2008
    I'm cannot logon to BIOS setup because of my keyboard is freeze. I'm try clear the CMOS using the jumper but still same problem. Is there another way I can try?
  • Ehart Mar 19, 2008
    Wont power up, sent one in for this problem, and came back fixed. This ones out of warranty and i dont want to pay 500 to a worthless company (Acer). This seems to be a common problem, any solutions beside replacing mboard?
  • touchbases Apr 25, 2008
    Keyboard & mouse not recognized by any USB port. Tested them on different tower; they're functional! Tried using different ports both front & rear. Disconnected power supply for 15 min.; then restarted. Removed cover and disconnected USB cables to motherboard; then re-attached. Cleared CMOS by moving the shunt. Without keyboard input, I can't enter BIOS to enable/disable USB setting. All of above have produced no change in Mobo detecting USB devices. System is (8) months old. Thanks for any help.
  • 99 Answers
Is it your first time to use a usb keyboard, and a usb mouse?if yes .check your settings in the BIOS setup,maybe the usb setup was disable,make it enable.,then save and restart your pc.
Posted on Mar 17, 2008
My computer wont read my mouse or keyboard
Are these wired or wireless, USB or PS2 connections..
PS2 Connectors should only be worked when the computer is Turned Off
USB can be Hot Swapped..
If USB try another USB port ..If PS2 make sure they weren't swapped by accident
Check your BIOS
Try another another Keyboard / Mouse
Sep 08, 2017 | The Computers & Internet
I have optiplex 780, On stsrt up the diagonistic lights 2,3 and 4 keep on blinking and no display comes on the monitor. According to Dell 780 manuals, a possible USB error may have occured and re...
Shut down the computer, disconnect ALL USB connections front and back.
  1. Plug in just the keyboard USB cable and start the computer. If it does not work, try moving the USB plug for the keyboard and trying again. If you can't find ANY USB port that works, then your motherboard is probably fried.
  2. Once the computer comes up with just the keyboard, plug in the mouse and wait for it to work (should be almost immediately). If it does not work in one USB port,try another until it works... wait several seconds after plugging it in before deciding whether it works or not.
  3. Once you have a working keyboard and mouse, begin plugging in any other USB devices, one at a time and verifying that each device works. As with the keyboard and mouse, if it does not work in one port, try another.
    1. Note that some devices may take several seconds or up to a minute to fully be discovered and set up and you may have to respond to something on the screen.
Oct 18, 2017 | Dell Computers & Internet
Computer won't recognize the mouse
you can try it changing the USB connector if it is USB mouse,
Nov 04, 2012 | HP Wireless Comfort Mouse, Black
I have a F5L075 wireless Belkin mouse that I need instructions on how to sync it to the ubs device.
when you turn on the mouse and if you have the USB transmitter in your USB port, the computer should automatically detect the mouse and the keyboard, (make sure both the keyboard and the mouse are switched on otherwise the computer will not see it. also be sure that your batteries are new (or check them with a volt meter). you don't actually do anything called "sync" with the mouse or keyboard.
Mar 23, 2011 | Belkin Wireless Keyboard/Optical Mouse...
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
My computer won't start up and my mouse and keyboard are not working. Do I need to replace my CMOS Battery?
Yes turn off your computer and replace the Cmos battery. It seems that your keyboard and mouse is connected into the usb port of your computer, the usb function in the Cmos setup is disabled that's why your keyboard and mouse is not working. Upon checking the Cmos setup enabled the usb function and save the changes and restart the computer to take effect.
Feb 08, 2010 | Computers & Internet
I need to know how to sync the mouse to the usb..????
1. Insert the batteries into the mouse.
2. Plug the USB stick into the port in your computer.
3. Turn the mouse on (switch is on the bottom).
4. To sync the mouse with your computer, press and hold the button on the bottom left-hand side of the mouse. Then, press and hold the button on the USB stick immediately after.
Note: The button on the mouse is very hard to find. Look at the sticker that is on the bottom, and to the left of it is a very tiny button.
5. Once you press the button on the USB stick, the red light will begin blinking. Hold both buttons simultaneously until the red light begins to blink noticeably faster, then let go.
Note: This is hard to do so be patient with yourself if you can't do it on the first try.
Dec 14, 2009 | Belkin Mini Wireless Optical Mouse...
Wireless mouse freezes the screen goes white it is a dell monitor i have had for about 3/4 years and a cheap wireless keyboard and mouse which i have had for about 2and a half years just started today...
Are the batteries fresh in the keyboard and mouse? Do you have USB keyboard and mouse to try (to eliminate possibility of wireless keyboard / mouse failure) If you do have alternate (USB or PS/2) keyboard and mouse, make sure and unplug the USB receiver for wireless set before testing. Let me know results.
Jul 09, 2009 | Dell Computers & Internet
Can't get any mouse or keyboard to work
if the keyboard and mouse where usb try a ps/2 keyboard and mouse,
The cable probably shorted out the usb ports on your computer,
do any other usb devices work on your pc???
Apr 16, 2009 | Computers & Internet
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
