I have a newly purchased Onkyo TX-SR705....I also have a pari of Bose 901s with the dreaded equalizer that used to go through my old Onkyo's "tape Loop"....what/how can I hook it up? Or can I? Thanks...Wayne
  • ywain1 Sep 13, 2008
    Same issue. Can you be more specific on hook procedure?
  • 4,234 Answers
You can continue to use the tape in/out setup with the new receiver or use the Zone 2 line out to feed into the EQ taking the output of the EQ into a separate amp.
Dan
Posted on Mar 17, 2008
SOURCE:
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
http://www.retrevo.com/support/Onkyo-TX-SR575-Receivers-manual/id/2526bh749/t/2/
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
What EQ can you subsitute for bose 901's
Short answer. No.
If you have one, use it. Is there a problem, like wanting to integrate 901's into your 7.1 system?
Get a separate amp for the 901's and check Fixya for the dozens of solutions I have posted regarding how to do it.
Dec 06, 2009 | Onkyo TX-SR705 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
"The blue light around my volume dial does not light
Try resetting the receiver (you will lose your setup). I recently reset my receiver and the blue light returned. It's possible that the Audacity setup turns off the blue light because the volume is now being "regulated" by the equalizer.
Mar 26, 2009 | Onkyo TX-SR705 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
130 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
