Question about Canon PIXMA MP130 All-In-One InkJet Printer
PREFORMED NOZZLE CHECK
PREFORMED NOZLE CHECK, BLUE IS GOOD, MAGENTA, IS GOOD, YELLOW WILL NOT SHOW, I HAVED PREFORMED CLEANING AND DEEP CLEANING, MANY TIME'S, WHAT DO I DO!! CAN YOU CLEAN THE PRINTER HEAD ANY OTHER WAY!
    Genius:
  • 3,587 Answers
Do you have a manual on this printer?
also, see this for more assistance
Posted on Apr 25, 2008
SOURCE:
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
I have a HP OFFICEJET 6000 WIRELESS PRINTER AND I JUST PUT A NEW BLACK CARTRIDGE IN LIKE A MONTH AGO AND YESTERDAY I PUT IN BRAND NEW "MAGENTA,BLUE AND YELLOW IN I PRINTED ONE PAPER PERFECT ALL THE...
Check ink levels, if showing full go to the printer properties, printing preferrencess,servicess, nozzle clean,..after cleaning the nozzles check print quality..
Sep 08, 2011 | HP LaserJet 4700 Printer
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
I have done a deep nozle clean on the printer but the yellow still doesn't seem to be working
Sometimes you may need to run quite a few cleaning cycles to get it to work. 10-20 or more. You can try cleaning the print head using white vinegar and a lint free swab. The vinegar dissolves any dried ink build ups. This can make any ink jet printer work just like new if you do a good job. BTW it can be messy and you better like smelling like a pickle ;-]
Oct 24, 2009 | Canon Office Equipment & Supplies
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Cannot Print Blue; Prints magenta instead
What does a nozzle check pattern show. Which colours are present and how many lines are missing from the poor ones? What cartridge numbers are you using? Genuine or refilled? How old is the machine?
Jun 05, 2007 | Epson Stylus C86 InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
57 people viewed this question
Clive
Clive
old marine
old marine
Ekse
