Question about Coby DVD-237 DVD Player
Power problem After only using the unit 3 times, i went to go use it and the power would not turn on. you can hear a noise coming from the unit as if it is getting power but nothing happens, it won't even lit up. please help
  • Tmarcel Mar 18, 2008
    yes but is this something that gonna cost more than what i paid for it? i know it's not much it's just the fact of the matter
    Genius:
  • Coby Master
  • 1,550 Answers
Maybe you got a dry capacitor in the power supply take it to a repairmen
Posted on Mar 17, 2008
SOURCE:
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
Rudd central unit , turn A/C on[therm. inside] all U can hear is a Buzzing noise coming from the outside unit , found that [1] capacitor wire had been BURNT , changed wire , then changed capacitor , turned...
Hello
Before you buy a new condensor fan motor check the contacts to the motor are not worn or pitted.
Hold or push the contactor in by using an insulated screwdriver and see if the fan motor turns.
Also the start cap you bought? was it the correct one meaning mfd micrfarad?
If all the above checks out ok then you need a fan motor,you can wire the motor direct to check it also.
From what you describe it sounds like the fan motor is burnt up and worn out,not uncommon.
Mar 22, 2011 | Heating & Cooling
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
I turned on the tv last night and it worked for a few minuets then it went out. I unplugged the tv and then back in and I do not even get the red light on the Tv to show up?
It sounds like a power surge might of ruin one of your boards. How old is your TV, what brand, model. Always use a surge protector as the electric company will not take any responsibility. Try turning off the unit again and unplugging it. Leave it unplugged for at least 3-6 hours, this will give it enough time to discharge. Plug it back it. Turn it on, what do you see or hear. Do you hear a high pitch noise if only for a second or two. Do you see a pin light at the center of the screen for a second or two. Your tube could have went bad. It cost to much to repair TV's these days. If it is not under warranty. Consider looking on craigslist, there are some great deals on there. Hope this helps, let me know if I can help you further.
JimmyC
Sep 26, 2009 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
96buick lesabre custom noise coming from tank fuel pump?car runs fine.you can hear noise when you turn key before starting and after starting?3.8liter v6 133000miles,started making noise like a small motor...
fuel pump getting weak -change fuel filter first may be getting restricted making pump work harder but99% pump is just getting old-may fail soon
Sep 19, 2009 | 1996 Buick LeSabre
SENDING UNIT ???????
most of fuel pumps were in tank, wire corrodes is harness under right front seat floor pan to tank
if fuel pump buzz is heard and car runs and when it doesnt run you cant hear the fuel pump try
turn ignition off wait 10 seconds
turn ignition to on position to (prime or hear pump buzz)
no buzz fuel pump not working check fuel pump relay(swap with another) and try again?
you could use test light to pump wiring and make sure your getting power to pump on this prime test no power relay or wiring problem.
power at pump, but no buzz fuel pump faulty
Jul 01, 2009 | 1997 Isuzu Rodeo
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Coby DVD-237 DVD Player Logo
97 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
