Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
WBM35MW: Beeping Hi, a friend has a Whirlpool refigerator, that isn't refrigerating anymore. It is beeping, and at the same time in harmony with the beep- the interior light is flashing, the fan starts momentarly and the compressor clicks, all at the same time. Now I know some people would pay good money for a fridge that does all this. But she would prefer if the fridge just did what a fridge is supposed to do.
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging the fridge for ten minutes, this will drain power from circuits and can solve some problem of this kind.
If it did not work you have an electronic problem, probably a wire making contact or a faulty control board.
You can buy replacements here.
Or call the number listed on your user manual if you need to call a repairman.
Posted on Sep 13, 2008
How can i get my fridge to stop beeping?
Good Afternoon Friend,
I understand you want to know how to make your Frigidaire refrigerator, model# FRS3R5EMB, stop beeping. Please try pressing the "On/Off" button on the Fresh Food Temp side of the control panel. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire refrigerator is beeping, it is working great, just 8 months old
Good Morning Friend,
I see that you are having trouble with your Frigidaire refrigerator, model# FFHS2313LS, beeping. There could have been a possible power failure. In the event of a power failure, the 'power fail' alarm will sound three times. The 'power fail' alarm is an audible alarm only and does not display in the control panel. I suggest resetting your appliance, by either unplugging it, or shutting the power off at your homes circuit breaker, for 2-3 minutes. When you bring power back you will hear the 'power fail' alarm again. If you notice your refrigerator still beeping, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine why it is beeping. Hope this is helpful.
-Best Regards-
WP
May 11, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
I have refrigerator whirlpool gold.. making beeping noise how to make it stop i already replace the inverter box.. the repair man told me it was that problem so i replace that. still beeping.. WHY?
Do you have any more info on this problem, like when it started beeping, the pattern of the beeping, function of the refrigerator that no longer works while it beeps?
Oct 26, 2013 | Whirlpool Refrigerators
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Whirlpool WBM35MW
If you have reason to believe this is a problem...and I doubt it...you can get an ampere tester from a number of online sites. One vendor is harborfreight.com. They run at least 20 dollars. The meters double as household testers in some cases. Others are recording meters which monitor specific appliances plugged in semi-permanently.
Jan 24, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool WBM35MW
Further to my previous post, contacted Whirlpool Melbourne who acknowledged problem described and advised that warranty for sealed unit including compressor was five years not three. Gave me local Sydney service agent who called and after looking at unit said it was one of thousands with the same problem. Motor was too small at manufacture and complete sealed unit including larger motor would have to be fitted. All at no cost!!. Unit away for two days and have been told that larger motor will ensure no repeat of problem.
All I needed was proof of purchase, and obtained this from retailer Retrovision without problem even though unit was purchased in Sept 2004.
Hope this helps.
Cheers
Rob H
Nov 09, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
1,734 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
