Question about Palm Treo 650 Handheld
Please help!!!!!! i recently bought a palm treo 650 off of ebay. i recieved the phone and when i bought a new sim card from cingular and put it in the phone it is saying " no service-sos only"and "your phone cannot be used with this sim card" why is it saying this and what does it mean? how do i get service for my phone with this problem?
The phone may not be compatible with cingular service.
Posted on Apr 05, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
My voice drops out on palm treo 650
Sorry, no solution - just some added info. I have the same problem with a Palm Centro. Changed sim card (O2) but no improvement. Palm eventually replaced Centro, but fault persists. Anyone with similar problems / solutions?
Sep 13, 2009 | Palm Treo 650 Handheld
Vodaphone Palm Treo 650 and when I put my CHIP into
Hi, not really familiar with Plm devices but insert your sim in to the palm go to contacts and look for Copy to sim or something similar. Sim cards have limited memory,varying from 100 to 250 contacts and 30 to 50 sms.Last would be one by one.
Apr 23, 2009 | Cell Phones
Palm treo 650 phone
Greetings to all. I have just purchased a palm treo 650. It was unlocked so I was told, but it was not a GSM, It was a CDMA, My carrier is T Mobile and I dont know what I could to Make It Work, as t mobile has a sim card and this treo 650 does not. Is there any thing I could do to solve this problem?
Aug 28, 2008 | Palm Treo 650 Handheld
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Palm treo 650 wont get service
If the phone is new to you, (different story if it was working on cingular before .. let me know if it was)
It sounds like it is sim locked, the phone needs unlocking.
If you can contact the previous owner and ask them what network it was on and borrow a sim card from that network it will verify the phone isn't faulty or blocked
The previous owner may be able to get it unlocked for you via there provider else somewhere like www.650unlock.com will do it for about $15 (I'm not recommending them, just one of the first in a search) Its worth googleing "treo 650 unlock" and shopping around also check 650 forums for recommendations
Best of luck
Jun 08, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
Treo 650 not able to access sim card
The SIM card is dirty or scratched.
Try taking the SIM out and wiping it with a dry cloth... then insert it back in firmly. If that does not work, you may need to replace the SIM card, or find a way to get it to press itself more firmly against the phone.
- J.
Feb 26, 2008 | Palm Treo 650 Handheld
It locks up
are you trying with a used sim card? if so try with a complete blank sim card and see if it frezzes. if not frezze before put your own sim card delete all contacts from card. cheers
Aug 23, 2007 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
95 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
