Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Belt not turning
The belt on our DC07 isn't turning, though the motor seems to be running fine. The tension on the belt seems fine. We have two long haired dogs which is why we bought this model and mostly it works fine as long as we clean the dog hair off the brush regularly.
Please help!
  • Anonymous May 14, 2008
    the motor works fine. I cant find the instruction booklet. the brush is not turning so i assume it is the belt. i cant get the vacuum apart to look inside to see for sure,i took all screws out and nothing is coming apart. sure would like some help.
  • Anonymous May 23, 2008
    Brush not turning. Cleaned all hair & lint off Brush belt ok . Nedd to know how to get to upper part of belt to see if it is jamed with paper clip or tooth pick.
  • 328 Answers
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Posted on Apr 19, 2008
Brush will not turn
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber or see small pieces of black rubber? Look in your manual for replacing power head/brushes belt! With the unit off , try turning the brushes by hand and clean them off of debris, etc., as well while there. See if you feel some tension or hear the motor moving inside, indication that the belt is still attrached and if it doesn't seem to have any resistance and you see small pieces of rubber and /or, the band/belt may have just broke from normal usage. WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Apr 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My beater bar will not turn. The motor runs but
This certainly suggests the clutch has packed up, although it is possible that the belt that runs from the motor to the clutch has failed (I assume you've checked the other belt, as it's very easy to see). Changing the clutch, and the motor-to-clutch belt, is not a job for the faint-hearted. If you want to see what's involved go to www.dysonmedic.com scroll to the bottom of the page and click on DC07 clutch replacement.
Feb 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Help, the brushbar on my Dyson DC07 vacuum quit rotating. Belt seems to be ok. How do I fix this?
The belt may seem okay and intact but it can be stretched. If it is stretched then it will not turn the brush when it is on the carpet. Here is the belt you need:
Dyson DC07 Belt
Feb 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
THE BRUSH DOESN'T SPIN BUT THE BELT IS ON IT.
this is a simple job for the mechanically savy person like you...Unplug the vacuum, use your hand to turn the brush, and watch the belt turn as well. Check the belt tension. Your problem would probably be clogged brush, belt-tension/misaligned brush or ultimately bad motor. If you can't handle it, get help from a friend or try appliance repair shop.
Nov 06, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt stopped spinning but has tension onit. I suspect the transmission (?) is stuck in the upright position and keeping drive in neutral
could be the transmission....more likely the motor has seized.
easiest to remove the motor once cooled and check for power or turn by hand
Sep 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Trying to replace roller brush on DC07 model
Hi the dyson is a bit strange with this the dyson engineers use a hook to put under the belt and pull it out to allow the brush to be removed I used a metal coat hanger to make the hook after seeing the dyson engineer when ours was under warranty if you make the hook with the wire doubled up it works fine for me hope this is of help Fred
Jun 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushbar not rotating but vacuum has suction - belt not broke
At the point where the shroud is around the drive belt of the motor there is a screw that has to be remeoved. It is accessible through a hole in the housing that is inset about 3 1/2 inches. Once this is removed along with the 2 screws at the base of the clutch housing, the shroud can be removed. Interestingly enough, though, I cannot figure out how to replace the brush belt even though I feel the clutch is the broken piece. Anyway, a new clutch with belts runs about 35-60 USD.
Jan 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
342 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
