Question about HP Compaq Presario V2000 Notebook
My presario v2000 speakers constantly hum,it has to be on mute always.what is wrong ?
I want audio driver
Posted on Feb 18, 2009
Try muting your only your microphone. The microphone could be picking up white noise and amplifying it through the speakers. Good luck!
Posted on Mar 17, 2008
I hooked up some speakers get humming sound nothing else. mycomputer says no speakers installed. So i cant do anything with the volume. Its not on mute. What can i do? I have a compaq presario...
Hi! The speaker installed may be defective which can cause the speaker to fail. Try putting a different speaker and see how it goes. Hope this helps and thank you for using FIxYa!
Aug 31, 2010 | Computers & Internet
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have a Compaq Presario V2000 Laptop and when I try to turn it on, the Caps Lock and Scroll Lock blink constantly but the screen stays blank. What is the problem?
just remove the ram and clean it and fix it again or you can try with connecting other monitor and make sure the laptop is booting properly only problem with screen.
Jan 20, 2010 | HP Compaq Presario V2000 Notebook
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
I want to install external speakers to my Compaq V2000
There are quite a few speakers on the market of different sound quality. I sugest you get speakers that have a built-in amplifier and you connect the powered speakers into the headphone socket on the laptop. Take you laptop to a computer shop with a CD and or DVD and test it with various speakers and then select one that suits your tastes and budget.
Jun 04, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Sep 22, 2008 | Altec Lansing Multimedia Computer Speakers
Pc speaker
You go through control panel option sounds & audio device there you will get enable speaker option check that one.
Feb 13, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
