Question about Sony STR-DA90ESG
Protector mode I have un hook every wire just the reciever and still having issue any ideas
  • Anonymous Mar 28, 2014
    Red and black plug on mother board
The problem is that the output transistor(s) are shorted causing the unit to shutdown in what is called "protect" mode. This is a common failue and should be easily repaired by a service shop for about $25-$40 in parts plus labor.
Dan
Posted on Mar 17, 2008
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
I hava an accurain 5048,reciever sound shuts off,protector reads
as you have described the unit is in protect mode. disconnect all cable/wires to this unit. - and try again. if it is still in protect-a definate short within this unit.
Mar 06, 2010 | Audio Players & Recorders
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
Every time I try to turn on my onkyo receiver it turns off instantly
the reason why the receiver probably keep turning off is that the systems come with overload protector to keep one from burning or short the systems out so it shut its self off. make sure you have the speaker wires is connected properly, its very important that you do although the receiver has 0% tolerance when it come to speakers hook up. positive from speaker to positive connector behind reciever; same as negative. double check all speakers wires. repost if that not an issue
Oct 03, 2009 | Onkyo TX-SR605 Receiver
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Immediately shuts off when turn on.
get another speaher wire two wires are touching making ti go into protect mode..
Jan 15, 2007 | Onkyo HT510 Receiver
Sony STR-DA90ESG Logo
240 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
