Keeps skipping and like there a short in the earphones. I got new earphone and still did the same thing.
  • 8,596 Answers
You will need to get that player replaced if it was doing the same thing with two different sets of headphones. Then again, headphones in mp3 players are sensitive - if you turn and twist the headphone jack around too much, then you will get serious distortion.
Posted on Mar 17, 2008
It's a pay as you go phone. It's asking me to remove earphones when I have never ever used an earphone. What can I do
try to clean it earphone port. maybe it have short in there. using small earbut and alcohol.
Sep 21, 2015 | Samsung Cell Phones
Problem with my earphones.samsung shg-j700
go to options while you are listening to music & then select "earphone on"
Jul 24, 2012 | Cell Phones
I PLUG MY EARPHONES IN MY CELLPHONE AND IT SAYS ENHANCEMENT NOT SUPORTED
First try it with another Earphone....and if the problem persist you need to check the internal hardware problem.Sometimes this problem occur if the earphone filter is shorted.(connected).You can do it by yourself or visit nearest mobile repairing shop.Good luck
May 01, 2012 | Nokia Cell Phones
Whenever i plug my earphones into my mp3 player I cannot hear my music through the earphones. any idea what the issue could be?
The wire inside the earphones Tore. If these earphones came with the Player then they are probably not very strong earphones. Usually the name brand ones are more durable. I believe it is time for you to buy some new earphones.
Dec 29, 2010 | Philips GOGEAR SA6045 MP3 Player
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
Mp3 promblems
have you tryed changeing the batterys?
Id take the player to the shop where you got it for a replacement if it keeps up.
Not much we can do on such a simple device.
Mar 17, 2008 | RCA TH1101 MP3 Player
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Songs and radio skips like a scratched cd
Your mp3 player works like a hard disk, make sure that it was not moving when you are listening to your music. If the problem is the same try to use a new headset/earphone on it. Loose connections on your headset/earphone makes you think that your mp3 player skips.
A Simple Thank you is Good enough
Jan 16, 2008 | SanDisk Sansa e200 MP3 Player
Earphone pads
i think so that you purchase new earphone and simply unjack the previous earphone and put the jack of your new earphone in the socket.thank you
Jun 16, 2007 | Aiwa XP-R232 Personal CD Player
64 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
