Question about Motorola Mobility RAZR V3xx Cellular Phone
Wallpaper How do I get the AT&T from being displayed on the main screen? It gets in the way of my Stewie wallpaper:(
Change the layout to left justified under the settings. that should move the date and the name of the service to the top left.
Posted on Apr 06, 2008
Why is my samsung xe3o3c12 keep changing colour when i open it
This is just the background. It's set to dynamic or "live wallpaper"
To change follow these steps.
Step 1 Press the "Home" button to return to the main screen.
Step 2 Press the "Menu" button and tap "Wallpaper."
Step 3 Tap "Wallpapers" or "Live Wallpapers" to access the selection of preset wallpapers. Live Wallpapers are simply animated images, such as bubbles, clouds or smoke.
Step 4 Tap a thumbnail and then "Set Wallpaper" to apply it to the Home screen's background.
Nov 21, 2014 | Samsung XE303C12-A01US Chromebook Silver...
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
I have the Optoma Model EP719 running. When I turn on my computer the projector shows my computer screen as it boots up. As soon as my desktop wallpaper and icons appear on the laptop screen, the...
right click on main screen, then go to properties, then you can adjust resolution, color, contrast, hue, and much more. You can also do this from control panel and under display.
Oct 08, 2009 | Optoma Office Equipment & Supplies
How do i change the picture on the maine
from the main phone screen, push the menu button --> options --> phone display options--> where is says show dial pad, the other choice on the drop down menu is show wallpaper, then click the picture to the right, and any picture you have in your phone you can use as a wallpaper for the main screen.
Jun 29, 2009 | Palm Treo 500 Centro
Turn off clock on my phone.
Main Menu> Settings> Display & light settings> Display> Wallpaper> Choose images (this will just disply a small clock at the top) or choose "Use Theme" (this will let you choose what clock sort you want on your wallpaper (do this by choosing "Use Theme"> Save> My Theme> Select Theme> Chose one of the 3 themes))
DO NOT choose "Living World" as this will display a large clock
Hope this helps
Mar 26, 2009 | Samsung U900 Soul Cellular Phone
Changing wallpaper on samsung f 480 main screen
YES YOU CAN CHANGE THE MAIN SCREENS WALLPAPER. sIMPLY TRANSFER ANY BMP OR JPG FILE INTO YOUR IMAGES, THEN SIMPLY SELECT MENU, MY FILES, IMAGES, TOUCH THE IMAGE YOU WANT TO USE, SELECT OPTIONS, SET AS, WALLPAPER. OR GO INTO THE SETTINGS CHOOSE 'DISPLAY AND LIGHT SETTINGS', 'DISPLAY SETTINGS', 'WALLPAPER', 'IMAGES', THEN JUST SELECT THE IMAGE YOU WANT AS YOUR WALLPAPER.
HOPE THIS HELPS
Oct 18, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Cannot get rid of an unwanted program .
here's manual antivirus xp 2008 removal
http://www.2-spyware.com/remove-antivirus-xp.html
If you are having problems with your desktop or getting the nasty message when you boot up follow the instructions below, but use the above link to remove the virus. YES THIS IS A VIRUS AND NOT A VIRUS REMOVAL TOOL!
First you need to stop the program from loading on startup. This is what you do to stop it:
Start, run
Type msconfig
Go to Startup tab
(if you've totally removed the antivirus program, you will not find these files and you can skip to the gpedit.msc step)
Uncheck lphc35dj0e1an
Uncheck rhc75dj0e1an
Click apply, then ok
Restart computer
Then you need to delete the main files this program uses. Delete the following file:
C:\windows\system32\lphc35dj0e1an.exe
Delete the following folder and all contents:
C:\program files\rhc75dj0e1an
This should remove the program from your system but you probably still have a warning message displayed as your wallpaper in Windows and the virus removed the ability to change the wallpaper or your desktop settings.
To restore ability to change your desktop settings and select a different wallpaper and screen saver do the following:
Start, run
type Gpedit.msc
Navigate to User configuration, Administrative Templates, Control Panel, Display
Right click on Remove Display in Control Panel
Click on Properties and select Disabled
Do the same steps to change the following attributes to disabled:
Hide Desktop Tab
Prevent changing wallpaper
Hide Apperance and Themes tab
Hide Settings tab
Hide Screen Saver tab
You should now be able to use your computer normally and change the wallpaper/screensaver to something other than the warning message Antivirus XP 2008 set it to.
Jul 19, 2008 | Computers & Internet
Creative zen v plus wallpaper display.
Very rare - go ahead and replace it - it cannot be repaired - this is the only case of screen burn-in on an Mp3 that i have ever heard of, but it happens plenty on mid -1990s, early-2000s TV's.LCD monitors of all ages, etc.
Feb 18, 2008 | Creative Labs ZEN V Plus MP3 Player
I880 External Display
go to main menu then to settings push ok push ok on display/info
push ok on wallpaper can you see it now
Nov 05, 2007 | Motorola Mobility i880 Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
