Question about Mag Innovision LT976S 19" Flat Panel LCD Monitor
MAG LT976s Drivers needed
I had to reformat my computer today and I am unable to locate the drivers for my MAG LT976s. I checked MAG's website and could not locate them and multiple searched on yahoo and nothing. I am using Windows XP and have loaded service pack 2 and all the updates (except Internet Explorer 7). At present moment, the settings in the display properties are set to "default monitor" with and 800x600 resolution. If I attempt to change them, things get really ugly looking. Could you provide me with a link to get the drivers I need to make my monitor work properly? Thanks!
Paul
  • 1 more comment
  • mkutch Mar 17, 2008
    I found what I was looking for after talking to the MAG support team. Thank you for your time and effort!
  • bambam1122 Jan 30, 2009
    MAG 900 LT976s Drivers needed?
    I replaced my DVD-ROM and put the cover on. When I press on the PC, the screen reads Analog RGB Searching then Digital RGB Searching then Analog Searching. All in about 4 seconds. Then the screen says, No Input Signal, Going to SLEEP. Then the Monitor power light turns orange (stand by?).
    Help Me OBee-Wahn Kanobee, You're My Only Hope
  • Anonymous May 11, 2010
    Did you install the correct video card and chipset drivers?
    Is it showing 16 and 32 bit as options under the "settings" tab on display properties?
SOURCE:
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SOURCE: My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Posted on Mar 18, 2008
SOURCE: Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Posted on May 15, 2008
jerryg50
  • 1691 Answers
SOURCE: Mag Innovision LT576S monitor goes blank after 2 seconds
I would think that the monitor is the issue, especialy that in safe mode it still does not function properly!
The fault with the monitor may be in the scan amplifier circuits, and or the power supply.
When I used to service these, I found many times that there were defective electrolytic capacitors in the scan amplifier sections and the power supply that gave problems.
This type of repair is time consuming, and when out of warranty it may not be worth the cost.
I would be seriously considering an LCD monitor.
Jerry G.
Posted on May 19, 2008
mukund_ce
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
I lost my remote where can I buy one
Look here for one Top Magnavox Remotes
They list 10 models click on each one til you find the one that looks like the one you lost. Then google the remote number they give for other sellers.
May 27, 2014 | Mag Innovision LT976S 19" Flat Panel LCD...
I have a mag innovision moniter flat panel butno power supply and can't find where one would even be on it
It took me an hour to find it. It should be on the cord that connects to the hard drive. At the bottom on the blue part.
Dec 12, 2010 | Mag Innovision LT976S 19" Flat Panel LCD...
My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
My ViewSonic monitor just blacks out for no reason
It could be a setting you could have done on the "Power Saving" settings under "Screen Saver" settings, if you have Windows XP. Like "Turn off monitor after" a certain time. Even if you don't have Windows, please check the Power Save settings.
MAG Innovision 19" TFT LCD Flat Panel Monitor
the monitor has bad backlights or circuitry. Call the company, their number should be in the owners manual. Or, look on the web for their website. Or, call the store where you bought it. The monitor must be taken to a service centre for repair.
Mar 26, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag Innovision LT976S 19" Flat Panel LCD Monitor Logo
241 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
