Question about Mitsubishi VS-55707 TV
I have a VS 55707 . Remote will not keep system turned on
When I click the remote the power on light comes on for about 3-4 seconds and then turns off. It gas done this several times and then without notice, it will stay on for several weeks until it happens again. I keep attempting to get it to power on and then all of a sudden it decides to turn on. I am unable to find the source of problem. Is there a component or is this a dead issue and not repairable. The tv has a beautiful picture when it is running. I have a smaller 45" tv same brand and type (projection) and similar problem. This one so far has not turned on once it started with this problem. I would so appreciate a hand with this.
  • Jay Wadsworth
    Jay Wadsworth Mar 29, 2008
    tHANK YOU SO MUCH. i HAVE RECEIVED SIMILAR FINDINGS ABOUT THE CAPS BEING THE PROBLEM. wITH THISNEW INFO i WILL ATTEMPT TO FIX TOMORROW. i WAS TOLD THAT THE VOLTAGE LIMITS OF 16 VOLTS IS NOT ENOUGH. tHE RIGHT VOLTAGE CHECK ACCORDING TOM THE OTHER INFO IS 1000UF @ 35VOLTS AND THAT WILL STOP THE EXCESIVE HEAT. i AM SURE SURE SURPRISED THE NUMBER OF PEOPLE THAT HAVE THIS PROBLEM. aLL CAOSED YEAR AFTER YEAR WITH THE SIMILAR PROBLEM THAT THE CAPS ARE NO HIGH ENOUGH CAPACITY. tHANKAS A BUNCH. iF YOU WOULD LIKE THE TEST SHEET AND THE PROCEDURE WITH THE LOCATION FOR YOUR OWN RECORDS, i HAVE BEEN GIVN A BEAUTIFUL PROCESS SHEET AND PICTURES TO FOLLOW.
  • 149 Answers
The problem is in your power supply there are small caps electrolityc capacitor that may be dry if you have esr meter check them and replace is around voltage regulator check for 25mfd at 200 volts or 4.7 mfd ..
Posted on Mar 29, 2008
Look for small capacity around regulator 2.2,4.7,10,or 25, mfd voltage maybe 150 to 250 volts just e-mail if you still have a proble I' will take a look to squematic and give you right part location
Power supply isn't working
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Dec 21, 2012 | Mitsubishi VS-70707 70" Rear Projection...
I have the Mitsubishi Big Screen TV Model number VS-55707. When I turn on the power the light flashes 3 times and will not turn on. It was working great then just stopped. I assume that 3 blinks on the...
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Dec 20, 2010 | Mitsubishi VS-55707 TV
Mitsubishi wd73733 wont respond to remote control
maybe your remote have a problem,try to open your remote control and change the crystal inside it,it is an orange color parts.
Feb 18, 2009 | Mitsubishi VS-55707 TV
TV turns off on its own
Set may have poor/cold solder connections on power supply board and convergence board.
Dec 17, 2008 | Mitsubishi VS-55707 TV
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Vs-55707
Press Input and menu together on the TV control panel and hold them for 5 seconds see if it blinks a two digit code.
Oct 31, 2007 | Mitsubishi WD-62327 62" Rear Projection...
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Mitsubishi Rear Projection TV
Easy! But you will need the original remote. On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
Aug 08, 2006 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 TV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
