Question about MicroBoards PF-2 InkJet Printer
Help my CD's are slipping
My disc seem to slip on belt. I clean and excercise the belts often. Any suggestions?
  • kevin gabrik
    kevin gabrik May 11, 2010
    Does this slipping cause blured print on the CD or DVD disc? And by cleaning do you mean that you take the cover off to throughly clean the printer?
    Problem Solver:
  • 9 Answers
I had the same problem earlier today. get a flash light with the printer lid up on the right corner should be a chuck of ink there remove that with a q tip and get some rubbering alcohol dip with q tip and clean the surrounding area you probably gonna need like 10 q-tips theres actually a sensor some where around there but i never seem to find it but most likely the run off ink is blocking the sensor from doing its job. once your done turn off the printer and unplug usb and power
Posted on Jan 14, 2009
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
My Nad belt drive turntable is running slow any ideas
stretched belt or needs lube, those are the easiest things, with the unit on, remove the disc so you can get to the belt, take it off the motor and see if the RPM's increase a lot, lube the center spindle with a light oil, and check for easy spinning ,, replace the belt, and turn the disc back and forth, if you see slippage or a binding in the belt, ( like a little loop wanting to develop) replace the belt, if the belt seems to be just slipping, clean all the contact points of the b elt with rubbing alcohol
Jul 02, 2011 | Audio Players & Recorders
Tray door sticks when you hit the open button
Hello,this is very common whats happening is the belt is slipping.You can remove the cover and belt and then simply take a q-tip and alchohol and clean the inside of the belt than reinstall it.Note there are 2 belts the one for the door is the one closest to the fron panel.Make sure door is ejected out and than power disconnected first.
Jan 06, 2011 | Yamaha CDC-845 5-Disc CD Changer
Disc draw does not close fully. The draw closes but the armature that holds the disc does not engage. Is is possible the drive belt is slipping and not allowing to engage the armature?? Advise please...
Hi:
This is ususally a indication that the unit is either out of timing, or like you suspect a worn drive belt, most modern DVD players use gears, but it could very well be belt driven, seems the clamper is closed when the tray trys to go in.
Nov 09, 2010 | Sony CDP-C910 10-Disc CD Changer
CD carousel won't rotate. Opens and closes fine, but will not change discs in either the open or closed position.
gears may have something obstructing them. Check and clean with dustaway. Gears may be broken jammed or slipping belt.
Apr 06, 2010 | Denon DCM-360 5-Disc CD Changer
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Nov 30, 2009 | Proform Crosswalk 500 Treadmill
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Clutch Slip
or at very low speed. The only way around it is to accelerate very slowly for a bit. After reading the forums I tried... -rolling the bike backward about 3' and examine the belt--the belt stays right at the top of the pulley. -examining the clutch--doesn't appear to be any rubber particles (shouldn't be as it was just replaced!) Also the drive belt is new. The only other thing to comment on is while I assumed I was buying a new clutch the red writing on the clutch indicates it is a rebuilt. That's all the info I have--any ideas?? Thanks! ,Slipping won't work for long. We have never seen slipping when all belt friction surfaces are clean. The belt should be totally dry and clean. The metal surfaces of both clutches can be cleaned with brake cleaner to remove any lubricants or oils that may be on them. Typically real slipping will destroy a belt almost instantly.,,,
Nov 10, 2008 | 2008 Ridley Auto Glide Sport
MicroBoards PF-2 InkJet Printer Logo
132 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
