Back to:
Tags:
Toshiba 42HP84 42 in. HDTV Plasma Television
42hp84
posted by Darr85 on Mar 17, 2008
I work at ABC Warehouse and i might be getting a defective 42hp84 but it has a black line from top to about the middle of the tv. Also if when you first start the tv colorful lines flash until I change the channel many times and it goes away. But the line still stays there no picture. Is it possible to fix this for cheap. do you have any idea what it might be what part needs to be replaced if so can you email me at justin_darr@yahoo.com thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Flat Panel Televisions problems?
Toshiba 42HP84 42 in. HDTV Plasma...
the picture will intermitantly flicker and "fall...
the set turns on and plays great sound but there is no...
my tv doesnt turn on it has no power
while watching a click sound was heard the video went out...
need insruction to install table stand
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
