Question about NetGear WG111 802.11g/b Wireless Adapter
Netgear usb not getting IP Address
My Wireless Netgear USB is installed to my computer my it cannot find my IP address from my router/network at which it detects but not my IP Address. Please Help!
  • Chris0310 Jun 03, 2008
    Think I'm having the same problem with the WG111T adapter. Just had Tiscali installed at Mum in law's and took existing pc and adapter which worked fine at my house. Put WPA key in that is on bottom of wireless router provided by Tiscali and it doesn't want to connect at all. Netgear seems to think it is wep so put in as key for Wep and get constant searching with it intermittently recognising the tiscali connection then carrying on searching. Will try downloading the software suggested and see if this works for me. Thanks for the advice and hope it works.
  • Anonymous Mar 13, 2014
    Netgear wn111 how to login what is the username and password? Please help me I cannnot use my netgear
I've just had a similar problem with my WG111T connecting to a Tiscali provided Thompson ST585 router.
My problem was that my WG111T was reportedly connecting OK to the router but that then the router would not assign an IP address to the PC.
I figured out the following - download the latest WG111T driver from Netgear (I used 2.1 from http://kbserver.netgear.com/products/WG111T.asp).
Follow the instructions to deinstall your old driver and to re-install the new.
THIS IS THE IMP BIT. When the Netgear instalation process gives you the option to use the Netgear config - it;s marked as (recommended) then DO NOT pick this. Instead pick the std. Win XP config option.
This then meant that I could control the input of the security key myself.
This worked for me!
Why? Well i'm guessing here but I think it's to do with differences in WEP / WPA-KSP.
Anyway hope that helps
Posted on May 18, 2008
    Genius:
  • 3,587 Answers
SOURCE:
Have install netgear range booster to wireless router but says limited connectivity
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Feb 19, 2011 | NetGear WPN111 RangeMax Wireless USB 2.0...
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless connection - can not renew the IP address
Here's what you can do Sometimes you can simply right-click the computer icon in the task bar near the clock of your XP desktop (If this icon is present). This will go through a process of resetting your IP address.
But if you do not have this option, you can go to START>RUN and type cmd. At the command line type ipconfig /release (or winipcfg /release in earlier versions of Windows). Then hit ENTER. Next, type ipconfig /renew and you should get a new IP address from the router.
If this doesn't work, renew the IP address. You will have to nullify the IP address on the PC, then shut the computer down. Next, unplug the cable modem for a couple of minutes, then plug it back in again. Once all of the modem lights are green, power up the PC again. It should automatically renew its IP at boot.
Unplug the router, then plug it back in AFTER you plug in the modem, but before you power up the PC. The router will need to supply the PC with a new IP address. Good luck, hope this helps or gives you something to try.
Apr 11, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Re set wireless usb adapter
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
May 18, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
NetGear Wireless Router and connecting using a USB Modem
I think you're saying that you want to set up a Netgear from a wirless port. Is that the ONLY computer you have?
It's not IMPOSSIBLE, but it is improbable. By default, the Netgear has the address 192.168.1.1. If nothing else on your network has that address, it might be possible to plug in the Netgear, set the IP address of your computer to 192.168.1.2-254, and link to 192.168.1.1.
I didn't say easy, just possible. Easy would be to use a computer with a wired ethernet port or grab a friend with a laptop with a wired port. It's a 15-minute job.
Carl
Apr 10, 2009 | NetGear WGR614 Wireless Router
Netgear wg111v2 wireless usb adapter wont acquire ip address
Not sure if this is where you are looking, but it probably is. click START then CONNECT TO then SHOW ALL CONNECTIONS then right click LOCAL AREA CONNECTION click STATUS then SUPPORT,,,
or CONTROL PANEL then NETWORK CONNECTIONS then right click LOCAL AREA CONNECTIONS then click STATUS then SUPPORT tab
See what you have there for an IP address
Is it the computer you don't have an IP for or the router? In my case my computer IP the 8th or last digit is the next number after what it is for the router. The other numbers are the same
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Connection problems
Is wireless connection enabled in your routers wireless settings and not encrypted in any way until a connection is established. Make sure your router is set to enable DHCP, as this will give your wireless card an IP address automatically. Ensure your card is set to obtain an ip address automatically. If not look in your routers setup(normally by typing 192.168.2.1, in your internet browser) to see what IP address and DNS address it has given your connected pc (eg 192.168.2.3). Then go into your cards properties and use the IP address 192.168.2.4, but the same DNS address(probably 255.255.255.0); then re start the wireless pc and the router if neccasary. If you still get no connection, ensure wireless light is on; on your router, and you have no obstacles in the way of the signal. If you are using WEP encryption it is normally a Shared key setting rather than an open key setting. Please reate this solution.
Nov 20, 2006 | NetGear Wireless-G USB Adapter...
Open Questions:
NORTON 360 TEch sUPPoRt pHoNe +{18OO.8O3..1O69 nUmber king Usa NORTON 360 USA phone number is ranked #2 out of 2 because 7,728 NORTON 360 USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he NORTON 360 USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, NORTON 360 USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON 360 USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON 360 USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON 360 USA Calling NORTON 360 USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON 360 USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON 360 USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON 360 USA's phone numbers against each other. Contacting NORTON 360 USA in General While I8OO8O31O69 is NORTON 360 USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON 360 USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON 360 USA.
Oct 22, 2019 | Norton Computers & Internet
See all NetGear WG111 802.11g/b Wireless Adapter Questions
NetGear WG111 802.11g/b Wireless Adapter Logo
626 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
