Question about Compaq Presario 2140US Notebook
Breakdown LCD CPU
I dont remember the model but the brand is EPSON.
Im sorry but i posted my inquiry on the wrong page.
Im having trouble with our LCD projectors, always breakdown no input signal, abnormal user operation and sometimes shuts down itself.
the provider has insisted our desktop PC is causing the breakdown which we doubted. If we dont see any bad video projected, seems normal then suddenly breakdowns i dont think it should be the PC> However we have used cabling made by us only. There is a posibility that our tech support has only wired the RGB Hor-Vert signals but failed to complete the groundings. There are instances that the video shifts to one side of the screen or sometimes jitters horizontally but occasional otherwise the view is almost as normal. after a few months ony of using, the LCD started to go eratic, shuts down and unable to start unless unplugged and restarted. In its worst condition, the LCD system will say no signal though it is hooked to the PC.
Main question only is that if such an abnormality will be caused by the desktop PC, HP Invent model using Nvidia FX5500 dual display, L:CD is hooked up to the DVI-converted to VGA output. Monitor frequency is set to 60Hzs only, resolution at 1024x768.
Or, can lack of grounding will cause the breakdown though POCD systems performs normal in its initial stage. from time to time losses horizontal stability.
  • Anonymous Mar 18, 2008
    can anybody give their opinion?
  • Compaq Master
  • 5,317 Answers
Wow a compaq forum , HP is correct forum nobody reads this.???
post to HP folks , i just stumbled on this.
wow are you a 1 PC shop,. cant try other PS with that PROJECTOR
Desktop or laptop.
gee? so simple a test, or move PC to projector direct, omg works.
and custom cabling,?????????oops RED FLAG
that is what is wrong,
ever read the VESA spec, on this, its tricky (2002 worst year ever)
if you connect that pc direct and it works well gee the cabling is wrong!
no distances stated, 10ft, 100ft 1001ft, what?
btw ive built these systems my self, even from scratch, (chips)
later, late 90s on.
they also sell pro grade, buffered VGA, controllers.
even from 1 PC and 5 projectors,
there are buffers inside that make the signals perfect at all times.
NO DISTANCE STATED!
do be aware you can not run COAX that far in most cases.
facts. (ig goes blurry, sync weak or goes to sleep mode)
only buffers work. (video band widths are wide and high)
One other system sold is a converter
that converts VGA or DVI to a custom data stream at the PC then decodes that at the other end for perfect signal. THERE.
one famous company that I bought from was
BLACKBOX.(tm)
talk to them been using them since day1, before went public stock.
https://www.blackbox.com/en-us/products/black-box-brand-products/video-multimedia
Posted on Jun 27, 2017
2 Suggested Answers
SOURCE:
  • 10406 Answers
SOURCE: cannot conect presario V4000 to projector
Set your screen-resolution to 800-by-600 at 60 Hz.
Then, use Fn-F4, to see if the projector accepts 800-by-600 input.
Posted on Apr 10, 2010
Im having trouble with the screen its very hard to push the screen to type anything and i when i use the the stylis it taps the wrong letter everytime
Do you have a protective case on the device? If so, it might work better if you remove it. Please give more details if you post again, such as the model number, brand, etc.
Aug 31, 2016 | Tablets & eReaders
Im sorry io got model nr wrong the correct one is 6564813000120 for my tv
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 02, 2016 | Televison & Video
I need to install MS-DOs 6.22 on IM-800 Poss Cash
First off... you need to identify the features your specific model has... While we personally have no software for this machine, we may be able to assist you in getting the machine up and running. This link will download a PDF brochure which shows some of the features available. Look it over and post your results.
http://www.crs-inc.com/files/EPSON_IM700_DS.pdf
According to this document, you could possibly run DOS 6.22 up to windows XP depending on drives, CPU and memory
Mar 31, 2010 | Epson IM-800 (IM50004040V) PC Desktop
I can install my epson nx400
Im sorry if you can install it why are you posting!
If you cant Install the printer what error are you getting and have you downloaded new software from
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
Aug 13, 2009 | Epson Stylus NX400 InkJet Printer
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Epson 3000 stylus inkjet not communicating with windows xp cpu
All I can do to help is to send you HERE to pick out a Mac driver.
Hope that helped...
Geno
Apr 04, 2008 | Office Equipment & Supplies
Blinking Ink and Paper light
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Jan 07, 2007 | Epson Stylus C86 InkJet Printer
Open Questions:
See all Compaq Presario 2140US Notebook Questions
Compaq Presario 2140US Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
