Question about Max Displays MD-219 (Gray) 19 in. Flat Panel LCD Monitor
Nvidia Vetro Geforce 6800GT on E510? Need help setting up max displays MD 219 dual displays
Hi all,
Hi all, I recently upgraded my video card to the Nvidia Vetro Geforce 6800GT from the stock Radeon X300 on my E510. I'm trying to run dual monitors on this system, however, my computer isn't picking up the second monitor; It does not give me the option to stretch the screen. I've installed and reinstalled the drivers and still no go. To be more specific, I have the Max Displays MD - 219 but I can't seem to get both monitors to come on at the same time. These monitors are connected and share a single power source. II've tried using two seperate computers to turn on both monitors simultaneously and that has worked, so it seems both monitors do power on and work properly.
I've tried hooking up just the right monitor and my old dell monitor to the card and it works fine with the extend desktop in properties/settings, but for some reason the left monitor just won't get detected (it gets stuck on a screen that says Self Diagnostics, Digital, No Signal, Check Signal Cable).
I tried using a Y splitter with the Left and right monitor, and both left and right displays come on with the same image, so from my understanding it's able to turn on and have an image. I've also unplugged the right panel when it was working, then plugged in the left one and that seemed to make the left one work; however, when I plug in the right panel afterwards they both go out. The Card seems to work perfectly fine as I can run both my old dell monitor and the right monitor as an extended desktop.
Does anyone have any ideas at all what I'm doing wrong?
Thanks in advance.
2 Suggested Answers
  • 1879 Answers
SOURCE: I have max displays md 219, 12v and I can't locate an ac adapter
Posted on Oct 29, 2008
Want faster processor for acer x1300 it base unit
Here are the spec on your pc if the information you gave me is correct. You can only upgrade the cpu to the socket you have. I think you would be better off adding more RAM and a better video card that isn't onboard. Processor / Chipset
  • Type AMD Athlon X2 7450 / 2.4 GHz
  • Number of Cores Dual-Core
  • 64-bit Computing Yes
  • CPU Qty 1.0
  • Max CPU Qty 1.0
  • Chipset Type NVIDIA GeForce 8200
Aug 18, 2013 | Acer Aspire X1300 Dual Core 2.4ghz, 3gb...
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
New computer is only recognizing 1 of 2 monitors
check your video grahics card application. change the display to mulitple set up. or go to panel display in the setting menu and change the monitor displays set to multiple or dual.
Jan 20, 2010 | Max Displays MD-219 (Gray) 19 in. Flat...
Laggy display after a few minutes play
lot of the game now a days require a pretty big video card. A 5200 is outdated and i know u cant upgrade your laptop. The best solution to this is increase the amount of RAM in your laptop to the max. When you run games lower the video settings to low or medium. Another thing that can help is running msconfig in the RUN box and turning off lot of apps that run in background
May 19, 2009 | Nvidia Geforce FX 5200 Graphic Card
Dualview display disappeared
just disconnect tv connection and plugin the monitor connector the display should come automatically.
then go to nvidia control panel and connect tv and then configure the dual display.
then both will again work again.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Dual monitor
open up the Nvidia control panel and identify monitors. Then run the multiple display wizard that should help you get both monitors working.
Move application window to the monitor you want it to be displayed on, close he application and reopen it.
hope this was somewhat helpful. Good luck!!
Mar 30, 2008 | XFX VGA |GF 6800GT 256MB PVT45GUDF3...
Nvidia fx 5200
The only time that this can happen is if the driver is not installed correctly, as on install you are normally asked if you want to activate support for dual monitors, so if you havent already, uninstall the card driver, restart and install driver again from the cd or from the NVIDIA website. If you have already tried this my apologies.
Apr 09, 2007 | Nvidia GeForce FX 5200 Video Card, 128MB...
Driver Installation 6800GT AGP
Check on the internet to see about compatability with your card and motherboard. In the past i have had problems with nvidia cards on certain motherboards, but alwas found ATI cards to be ok.
Nov 16, 2006 | MSI NX6800GT-T2D256E GeForce 6800GT, (256...
Max Displays MD-219 (Gray) 19 in. Flat Panel LCD Monitor Logo
53 people viewed this question
Top Max Displays Computers & Internet Experts
David Payne
David Payne
Are you a Max Displays Computer and Internet Expert? Answer questions, earn points and help others
