Question about GE JVM1870 Microwave Oven
Cuts off immediately
My Ge JVM1870bfo2 cuts off immediately when it is turned on.
  • GE Master
  • 9,174 Answers
Do you mean that it stops and goes back to a state as if you unplugged it whenever you hit the Start button to cook?
If not, please reply back with specific details.
If you do have the symptom I described, then here is your solution, and sadly we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
SOURCE:
Our ge profile microwave only stays on for 5 seconds then cuts off.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts off when gets too hot
inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Jun 06, 2010 | GE JES1142SJ Microwave Oven
The oven keeps on running and want cut off
This was a huge issue with GE a few years back. They had a series of microwave ovens that would turn themselves on and not turn off until unplugged or the electricity was cut. You need to stop use and disconnect the power from the microwave immediately by any means and research GE's recall process to get a new one or simply throw it away. This is an extreme fire hazard and has started fires before so please get rid of it, whatever you do afterward is up to you.
Apr 27, 2010 | GE Microwave Ovens
Microwave cuts off after 3 seconds. Magnatron?
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 21, 2010 | GE XL1800 1100 Watts Microwave Oven
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave
try to hold the door closed when you first start it set the timer for 1 min with a cup of water inside press start and then hold the door in if it reuns your door is out of aligment or the interlock switch is popping open
Jan 24, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker Microwave Oven Problem:
if a microwave cuts off when cooking, then there is a problem. i have never heard of a " FEATURE" like that.
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1870 Microwave Oven Logo
85 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
