Question about Sanyo DS27910 27" TV
Volume controls dont work when using remote
I lost the original remote of my TV Sanyo DS27910, but my motorola cable remote operated the TV volume controls OK for one year. Lately, it has become off and on. Sometimes the remote works the volume controls, other times it does not. It is intermittent. I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, it operated the TV volume, but never worked again.
When pushed directly on the TV set, the volume controls always work, but I am having difficulties getting it to work properly on remote. 90% of the time, I cannot use the remote.
Please advice.
    Problem Solver:
  • 20 Answers
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Posted on Mar 17, 2008
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
I have a Sanyo DS27910 Flat Screen that is stuck on Video 1. My remote was lost in a move. I downloaded the manual but there does not appear to be a physical reset. Can you help me resolve this...
You can purchase the original remote for $20.99 base price.
http://www.replacementremotes.com/SANYO/Buy-FXRG-6450459313-TV-Remote-Control.html
Jun 10, 2011 | Sanyo DS27910 27" TV
Stuck on video 1
try to press the channel up/down if not working use a universal remote and find the code of sanyo .
Jul 29, 2009 | Sanyo DS27910 27" TV
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
My volume dont work on my virgin tv control
Contact the silver remote Mfr. or tell us the make / model of
the remote you have...............T.
OR www.mrremotecontrol.com for new Sanyo remote....
Please rate this solution..........
Nov 14, 2007 | Sanyo DS32920 32" TV
Menu arrows wont move
in your case, i'm sure the your memory in tv is def or your microprocessor is also def.
Oct 13, 2007 | Sanyo DS27910 27" TV
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Manual Controls Not Sufficient
If you have a "Menu" button on the front panel of your set, then you may be able to change settings from the menu this way. If not then you will have to have the original remote to change settings. Stargazer
Sanyo DS27910 27" TV Logo
348 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
