Question about APC Back-UPS Pro 650 UPS System
SMART ups 700INET
TOO MUCH LOAD WITH OUT ANY LOAD REPLACED BATTERY
  • shindvs Mar 17, 2008
    one transitor burn out on front panel
    also one corroded pin on main board
No t required
Posted on Mar 17, 2008
SOURCE:
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
About ups
If you remove all of the equipment plugged into the UPS, is it still lit?
Are you sure this is an overload light, and not a replace battery light? If this is a smart-ups unit, the overload light is next to a picture that looks like an unbalanced scale. The replace battery light is a square with an X through it.
If it is, in fact an overload light that is lit, and it stays lit with less than the maximum load on it, or without any load on it, then you have a critical internal failure and the unit needs to be replaced or repaired.
You can also find your user manual here for more information: http://www.refurbups.com/Knowledge-Base
Mar 29, 2010 | APC Smart-UPS 1500VA Shipboard...
SU700net totally dead I have an SU700 that when plugged in is totally dead. If the batteries are dead should this still come on?
If the batteries are shorted out, the UPS won't come up. Try removing the batteries & test the device with the batteries disconnected.
Nov 28, 2009 | APC Smart-UPS 700INET (SU700INET) UPS...
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Back up problem
The time will lower the longer u keep using it. Every (Chemical) battery needs to be replaced periodically and maybe its time to change your UPS batteries too. Since you were using double battery, it is supposed to be replaced every 4 yrs or so if it is used regularly.....sodeep
Mar 31, 2009 | APC Smart-UPS SUA1000 1000VA USB&Serial...
No Power on output
check circuit breaker if it work properly change battery
Nov 29, 2007 | APC Smart-UPS 700INET (SU700INET) UPS...
Flashing lights
you may have to check the power cord and if that is in place and okay, you will have to check the fuse on the ups. if all that does not work, send it back to the comany for repairs or contact a repair personnel
Sep 01, 2007 | APC Smart-UPS 700INET (SU700INET) UPS...
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
APC Back-UPS Pro 650 UPS System Logo
52 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
