Question about Sanyo DP32746 32 in. LCD Television
Sanyo LCD TV DP32746 no picture
Picture went black, sound is good. Assume from my research CCFL(s) are bad. Attached is a picture of the set with back panel removed. Could it be the Backlight Inverter? Guess it makes sense to change the bulbs first since they are less costly. Appreciate your help greatly. Brad
  • 5 more comments
  • semidiyfer Mar 31, 2008
    I am having the same problem. When I hit the power button, the backlight flashes on for a second near the bottom but goes right back off. Sound works but no picture. How do you diagnose if its the bulb/bulbs or the backlight inverter, or some other component??
  • ArthurDent Sep 14, 2008
    I have the same problem, but my Sanyo model # = DP32647. It's also a 32" LCD screen TV. This afternoon I went to turn it on, the "backlight" flashed and the channel ID showed up, but then the screen went black as if the set had been turned off. Sound comes through fine, channels change OK (by the audio I hear, anyway), etc.
    So what is a ccfl?
  • CAPTHOOK17 Sep 30, 2008
    NO PIC ONLY SOUND SAME AS EVERYONE ELSE. PLEASE HELP
  • paula333 May 21, 2009
    32 inch sanyo LCD TV with sound but no picture. please let me know if what you do solves the problem.
  • semidiyfer May 11, 2010
    I am having trouble finding ccfl's to replace the ones that are bad. I have the Sanyo DP32746 lcd tv. It is a 32" tv with 16 individual ccfl's. Each one is very small diameter, about the size of a pencil lead. I have sent an inquiry to Moniserv, waiting for a response. The lcd backlight panel is a AU Optronics Model number T315XW01 V.5. My fear is the panel and ccfl's are sold as a unit which is going to be way more expensive than replacing ccfl's. Any suggestions??
    ikenfixit,
    So if I understand what you are saying, then if one of the ccfl's goes bad they all go out, kinda like christmas lights that are in a series circuit?
  • Anonymous Mar 21, 2014
    Updated firmware and reset the TV, during the diagnostics scan I got a "sos:01" result highlighted in red. I did a little research and this probably could be a faulty inverter board, does it makes sense to you?, what about backlight?
    Scholar:
  • 163 Answers
Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. Moniserv.com for replacements.
Goodluck guys!
Posted on Apr 04, 2008
  • Ken LaDere Apr 08, 2008
    Its a safety circuit and built into the Inverter for some reason. These usually have at least 4 Bulbs and yes if one goes out the inverter suts down.
I had the same problem great sound but know pictur , after removing the back i noticed the cable going from 1 off the boards to the manualy operated button for channels and volume was streched and wer it was plug into the board the one of the pins had broken , i just sniped that particular wire going to that pin and solderd it to the point on the underneath of the board wer the broken pin was located and it worked fine , and at least i found out that it was that cable was controling the picture anyhow along with the board it was atached two
Posted on Feb 29, 2012
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
My Sanyo DP42848 has audio but no picture. How can I fix it?
i turn my sanyo on and its all good for a few seconds then i loose picture but still have sound ,,whats wrong?
Jan 21, 2011 | Sanyo DP42848 LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
The picture is out totally but have sound
Goodluck guys!
Aug 17, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
The power button lights up but no sound or picture.
Check to see if the set is under warranty or an extended warranty.
If not, ouch, but do-able.
From least to worst case, possibilities include
1. Bad panel drivers (between the Y-Sus PCB and Panel)
2. Bad Y-Sustain board or equivalent.
3. Bad power supply.
4. Control PCB.
5. Bad Panel.
Or any combination of...
I would recommend that you have a certified and factory authorized technician repair your set. Or at least diagnose it. Not always is it just replacing a board. There are adjustments that need to at least be verified by a knowledgeable technician.
Wouldn't want to get zapped. There is High Voltage back there.
You might also try entering the make and model number of your set online to search for others with like problems on the same model. Odds are that it has happened more than just once and that other techs may have a definate solution to your problem.
Just takes a little research.
Good luck.
Tim
Certified TV
Jan 11, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 no picture, sound good
If there is still sound its the back light inverter, if no power at all its the ccfl
Mar 17, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo lcd 32" vizion integrated hdtv
I have this tv as well with the same problem. From the research I've done, one of the 16 ccfl's(backlight bulbs) goes bad and they all will not come on then. I have not been able to find a replacement ccfl for this particular tv. The ccfl size if 3mm x 711mm. I have a feeling the scope of this problem is very large with this particular tv and this forum represents the tip of the iceberg. Sanyo unfortunately makes a piece of junk and we have that piece of junk sitting in our homes with no good solution other than to say, dont waste your money on another Sanyo tv.
Jan 09, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
3,602 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
