Hola
Defective printing does not print crisp, white out in print, or not even print anything, just move the spool and nothing appears, the colors go wrong. However, in these cases is that we have a cartridge slightly obstructed or completely clogged with dried ink if you have heavy, it is likely that the ink has been of poor quality and dries faster than usual, or perhaps use the printer and let a long time without use, this causes the microholes clogging, which in turn prevents the proper exit of the ink causing a bad impression.
The fastest, homemade solutions: Remove the cartridge from the printer, and then immerse the injector in a little warm water, leave it there for a while, then off, dry it well and perform the head cleaning process in the configuration utilities for our printer. / With cleaner (cleaning product containing alcohol and ammonia) do the same procedure as above should not work.
But sometimes, the problem is that there is air inside the cartridge that is inserted into the sponges, and instead of heat resistance ink what they get is only air. To fix it we will locate the top holes of the cartridge, where it enters the ink, and putting a napkin where the ink comes out we will proceed to introduce air (by the way you like, blowing, or injection) at the top and let that little bit of ink. proceed to clean heads to the usefulness of the system and ready.
