Question about Canon PIXMA MP130 All-In-One InkJet Printer
Error 5200 my printer comes up alarm flashing with check printer 5200, can anyone help
  • dollah Mar 22, 2008
    error 6000 - ink absorber is almost full? how to change?
  • Anonymous Apr 02, 2008
    Error 5200... How can I fix it?
    Guru:
  • 1,342 Answers
Posted on May 12, 2008
SOURCE:
Error 5200
No. Lots of printers are guilty of this s---. Manufacturers want you to use their product so they can hose you.
Check this out in google for solution to this nonsense. Canon will not, for obvious reasons, help you.
Aug 30, 2015 | Office Equipment & Supplies
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
my printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Jan 18, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Dec 22, 2009 | Canon Office Equipment & Supplies
My canon pixma mp170 says check printer on the screen with error code 5200 and the alarm button is flashing
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Dec 16, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Error code 5200...
5200 is an abnormal temp. rise in the printhead. Not related to your other problems, but you need a new printhead. QY6-0063-000. Around $50.00
Apr 15, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Error 5200
Try cleaning the pick-up rollers with rubbing alcohol. Use a rag, soak it with rubbing alcohol, then rub it on the rollers. Try to spin them also. If that doesn't work, then you need to have the printer serviced or you can try and change the pick-up rollers.
Mar 24, 2009 | Canon PIXMA MP240 All-In-One InkJet...
What does error code 5200 means
ok and error 5200 ushally means it has something to do with the printhead but we are going to try this just because it is the easyest and known fix for this error.
First off unplug the printer from the computer
secound turn the printer off
third unplug the printer from the wall
wait a minute
plug the printer into the computer then into the wall then turn the printer on
do a test print
This should have solved your problem but if it didnt please let me know and I will see what other things we can try to help you fix this issue.
Oct 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
795 people viewed this question
Clive
Clive
old marine
old marine
Ekse
