Question about Refrigerators
Frigidaire phsc239dsb0- temp controls
We had an electric diode replaced a few days ago and now all of a sudden the temp controls are flashing E for the freezer and F for the refrigerator side. I reset the circuit and turned the fridge off and on, and it was ok for awhile but now the E and F are flashing again. The fridge is running and cold. Any thoughts? The Frigidaire book says to call in when temp controls are flashing, which I'll do on Monday, but thought I'd ask here, too. Thanks.
  • Ta2aki Oct 19, 2008
    almost every month, it starts "clicking" and temp goes high. Then, I have leave it off and open to defrost internal part.
    Today, I opened the back panel inside the freezer and used hair dryer to defrost. I re-connected the power and noticed the E and F codes were flashing. I disconnect the power and re-connected. Not it seems workng and getting cold. Let's see
    President:
  • Refrigerators Master
  • 2,651 Answers
E-f relates the evaporator fan. lasttime i had that happen it was problem with the mother board located under the refrig, replaced it and all was well
Posted on Mar 17, 2008
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 25, 2015 | Refrigerators
WHERE IS THE MAIN CONTROL BOARD LOCATED ON A FRIGIDAIRE REFRIGERATOR PHSC239DSB0
Behind front grill below the doors, on the left in a box held in by one screw. There are two screws there. I unscrew the one pointing up so the metal bracket comes out with the box.
Feb 03, 2013 | Frigidaire PHSC239DSB Side by Side...
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer
I was unable to locate a similar complaint through my service database, so this is going to be a hit or a miss answer.
This model has an electronic control board in it and it is possibly picking up a static discharge from your body and powering up the start relay. This may be due to improper grounding or a recent power issue. This type of failure apparently does not happen with a 240 volt appliance often enough to be in the books. I might suggest that you unplug the dryer for 10 minutes, then plug it back in to see if it corrects the problem. If not, you will want to have your outlet inspected by an electrician. You may also have to replace the control board, if the electrician finds the outlet satisfactory. You may also just want to consult a factory authorized servicer that would be capable of checking the outlet AND testing the board before replacing it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 20, 2008 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
Jan 26, 2008 | Frigidaire FSC23F7D Side by Side...
Frigidaire phsc239dsb0 ice maker
Yes it is best to replace the whole icemaker.  Heaters don't go bad very often but thermostats do.  You need to know what you are doing to test these parts.  I would recommend replacing the whole ice maker and I have worked on thousands of them.
Oct 13, 2007 | Refrigerators
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
