Question about Sharp R-408HS Microwave Oven
Microwave installation under cabinet, no rear wall
I want to hang my over the range micro from the cabinet over my range. I have no rear wall to support the microwave. This because the range is on a peninsula and so are the cabinets above. Can I just hang the micro from the cabinet above? Will I need to reinforce anything? The cabinet I want to hang the micro from is securely bolted to the ceiling joist above it. Thanks
I want to hang my micrave under my cabinet it is not connect to the ceiling but it is to the wall studs
  • Sharp Master
  • 9,174 Answers
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
SOURCE:
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
Mar 02, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
Dec 17, 2017 | Samsung Microwave Ovens
How do i remove an old oven
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side, to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jul 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
Dec 26, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Who makes a microwave oven that mounts in an
Why can't you use the wall plate? Even if you had to use construction adhesive it would be better than nothing. If you are installing in an island setting then you will have to reinforce the cabinets as they would have to support the weight of the micro.
Eric
Oct 01, 2009 | Microwave Ovens
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-408HS Microwave Oven Logo
451 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
