Carpet wet on passenger side no easy explanation
If it doesnt smell like a coolant then there may just simply be a small plug has become loose on the front panels or the rain water is making its way in from the roof down behind the panels. This happens if there is a small blockage in the rain water gulleys as the water will find the easiest route.
A simple way to find out is remove a interior side panel , Get a little talcum powder , puff a little on the side. Go outside and tip water down that side and see if the talc becomes wet. You may see the trail of water flowing.
A 99% bet is that the heater coil is leaking. It is located in the dash on the firewall-passenger side.
