Question about Mitsubishi WS-55859 55" Rear Projection Television
Mit..ws55859 This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck........ can u please send me the fix to this thanks u
    President:
  • 3,130 Answers
I may have a fix for you if you leave an e-mail address.
Posted on Mar 17, 2008
SOURCE:
The green timer light is blinking with no interruption on my WS-55859. TV will not power on after the reset button is reset or is disconnected from power.
Thats almost always caused by failed DM capacitors on the DM power board. There are 7 that will need replacement. There is a repair kit called the WS55859 DM repair kit which has the caps and the CD with repair instructions available from www.tvrepairworld.com
Jul 07, 2011 | Mitsubishi Televison & Video
Green light flashing on timer. tv wont power up..just bought this house. wtv was left behind. i was told it works but i cant turn it on
Thats a common problem if the sets left unplugged or without power the DM caps drain and then wont charge when the power is restored. Its a easy fix usually just replace the DM caps. You can get the Mitsunbishi repair kit called the WS55859 DM repair kit from www.tvrepairworld.com which has the upgraded replacement caps and the CD with repair instructions.
Jun 14, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Timer light continous blinking,tv won't turn on!!!
Thats a common problem thats almost always caused by failed capacitors on the DM powerr board. You can get the WS55859 DM repair kit from www.tvrepairworld.com the kit contains the upgraded capacitors and the CD with repair instructions.
May 30, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Green light flashing in the front ?
SLinteriors posted this on another page and saved me big bucks.
Here's a bit more detail:
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Jul 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashing what does that mean?
The steady blinking green timer led is usually caused by failed capacitors on the DM and Power board which prevent the set from completeing the Boot sequence
Jul 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I have a WS 55859 and after power outage i got the green POWER light blinking. I replaced all seven capacitors 1000uf but i still can't switch it in? Any other advice? Rgds FM
If replacing the 7 caps doesn't work I then try to re-solder the small 8 pin ICs. Be very careful and try to avoid cooking it or leaving a solder bridge. If that doesn't work either you'll have to replace the DM-POWER board. You'll beed a Mits authorized service center to order the part. Goodluck.
Jul 05, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Ws55859
Misubishi WD-5237
T.V. will come on and display the satellite channel guide and will change channels,but will not display picture. Could this possibly be bad spot in coil?
Mar 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
