Re: My dvd is asking for a password to play the movie...
Try using the password 136900. If this works for you, then using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
1. Insert a DVD Movie into the PlayStation®2. 2. You should receive a message informing you that the Parental Level has been set, and asking if youý"d like to allow the disc to play. Highlight "Yes" and then press the X button. 3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button. 4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9). 5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password". 6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete". 7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing. 8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed". 9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off". 10. Now you should be able to watch any movie
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
I had the password problem with the Phillips DVP-5140. I looked up the user manual on the Phillips website and searched for "password". There is a manufacturer default password of 136900. I entered that number and was then able to play the DVD. The password may be different for other models, but you can find the default in the user manual for your specific model.
R/
MO-Help
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
