Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Dewalt DWo56 18 Volt cordless impact
Motor is weak, do these have brushes that could be worn? If so, where are they located? Thanks
  • Anonymous Mar 19, 2008
    bit got stuck inside shaft, cant remove it
  • Chris Oldfield Jun 20, 2008
    after using my driver all day installing some decking using 4" screws, it just wouldn't drive anymore. it did however still go round unloaded but when any load was applied ie to screw in anything, the thing just kept slipping.
    Champion:
  • 313 Answers
All drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Posted on May 27, 2008
Can you change just the bushes on a dewalt dw056
No, the brushes are part of the motor and pinion, Dewalt part number 607990-03. If you search "dewalt 607990-03" you can find several on-line vendors that sell the motor. They run about $50 plus shipping.
Jan 28, 2011 | Dewalt DW056 18 Volt Cordless Impact...
Problem to work
Either brushes or trigger. I would check brushes first. Juraj
Jun 06, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Hi from dublin,my third dewalt dw054 impact 14.4v cordless drill,they all lose power,as if the switch does not work,but i think the motor is gone.. They all went the same way after two years..great drill...
Hi there, the first thing you need to do is check the carbon brushes, there will be two of these one at each side of the motor, if these are ok then test if power is getting to the motor, to do this you will need to split the casing on the tool in half. You may need a torx driver to undo the screws on the casing. Once you have removed the screws, very carefully split the casing making sure you leave the gearbox assy, motor and switch in the other half. Insert battery onto the unit and get someone to hold the motor in place just incase the machine starts. get a voltmeter, follow the wires from the switch to the motor and where the wires attach to the motor put the probes of the voltmeter and pull the switch to engage it. You should be gettting a good voltage now, If you are then the switch is ok. hope this is of some help
Dec 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Drill Motor Reliablity
some models have external brushes for easy changing - when the brushes wear down you can easily change them for new ones, some models have this feature ,it is only of use if you are using your cordless drill on a daily basis.
Aug 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
1,113 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
