Question about HP PSC 2355 All-In-One InkJet Printer
Printer error message
I replaced the color cartridge with a HP95 replacement and when I put the lid back down I got the error message "Remove and check color cartridge." I did but nothing seemed wrong. I put the original back in and got the same message. A third cartridge did the same thing. I wiped the contacts with a Q-tip and got the same message. Anybody have this problem before?
    Novelist:
  • 188 Answers
Please use the same number cartridges that you have received with the printer else you will have to chage the zone of the printer and this could damage the print heads.
So, please be carefull, I am a technician form HP All-in-One printer.
Click on the web link given below and perform the steps carefully to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257066&cc=us&lc=en&dlc=en&product=422000
Have a great day!
Posted on Mar 21, 2008
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    I've received the error message: "Printer
    Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
    Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
    Incorrect cartridge error message when I replaced the cartridges with two new original HP cartridges. HP95 & HP96. The printer will not print. I have turned off and on the printer. I have rebooted...
    HpCartridge issue Completethe steps below in the order presented to resolve the problem. It might not benecessary to complete all of the steps. Stepone: Reset the printer
    1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
    2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
    3. Check the printer for the error message. If the error message still displays, go to the next step.
    Steptwo: Clean the cartridge contacts Figure1: Lifting the top cover clip_image001.gif
    1. Lift the top cover.
    2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
    Figure2: Unlatching cartridge clip_image002.gif 1- Black cartridge 2- Color cartridges
    1. Remove the cartridge indicated in the error message.
    Figure3: Removing cartridge clip_image003.gif
    1. Gather cleaning materials:
      • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
      • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
    2. Lightly moisten the swab and squeeze out excess moisture.
    3. Holding the cartridge by its handle, wipe the copper contacts.
    Figure4: Wiping the contacts clip_image004.gif 1- Copper contacts
    1. Replace the cartridge, then close the latch and the printer top cover.
    Stepthree: Replace the cartridge
    Dec 21, 2010 | HP Photosmart 2610 All-In-One InkJet...
    Lexmark 6170 Cartridge Error 50C How to resolve?
    "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
    1) Press Power to turn the printer off.
    2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
    3) Turn the printer on.
    4) Remove the color ink cartridge.
    5) Lower the printer (scanner unit) until it is completely closed.
    If the error message displays again, replace the black cartridge with a new black cartridge.
    If the error message does not display, repeat steps 1–3 and then go to step 6.
    6) Reinstall the color cartridge and remove the black ink cartridge.
    7) Lower the printer (scanner unit) until it is completely closed.
    If the error message displays again, replace the color cartridge with a new
    color cartridge.
    If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
    8) Lower the printer (scanner unit) until it is completely closed.
    If you get the error message again, while both cartridges are installed, replace both of the cartridges.
    Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
    You may have to buy a new cartrige.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
    Cartridge error 50c
    Hi there Error 50c
    Please try this.
    Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
    color cartridge.
    Dec 22, 2009 | Dell A940 All-In-One InkJet Printer
    Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
    Hi there Error 50c
    This is for yours.
    color cartridge.
    Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
    Cartridge Error, Error 50C
    Hi there Error 50c
    Dell gets this lots so have a try.
    color cartridge.
    Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
    HP PSC 2355
    Oct 23, 2007 | HP PSC 2355 All-In-One InkJet Printer
    Error code 1203
    To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
    Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
    HP PSC 2355 All-In-One InkJet Printer Logo
    156 people viewed this question
    Seeker5211
    Seeker5211
