Question about Canon PIXMA iP6310D InkJet Photo Printer
Canon printer Pixmaip6310D
How do you reset the print cartridges indicator to show full when you replace them?
  • 667 Answers
If your using regular cartridges and not the FINE ones, make sure put full cartridges in or indicator will read incorrectly. If you haven't gotten any error messages and said proceed anyway ( you'd know because it would've told you that this would disable your ink monitor), just put in the full cartridges and do a print head alignment and this should solve your problem.
Posted on Mar 18, 2008
SOURCE:
Will not print after ink replacementit shows
shut down computer
unplug printer from power outlet ( it must be unplugged )
remove both printer cartridges
make sure there is no tape or other items on cartage
reinstall cartridges
plug printer in
turn on printer
turn on computer
Feb 15, 2014 | Canon Office Equipment & Supplies
Online chat
Canon will make it hard for you to refill or use other mfg. carts. The have been using a small electronic fuse that can be reset with a device purchased from ink cart resellers. The chip on the cart is reset and the printer firmware thinks the cartridge is a Canon Cart, thus it works just fine.
Feb 19, 2018 | Canon Office Equipment & Supplies
I have an HP F4580 printer, and have just refilled both ink cartridges. However the printer won't allow me to print as it thinks the ink has gone. How can I reset my printer to display ink cartridge...
Often they have a chip mounted on the cartridge which monitors usage and when it determines that there is no ink remaining, it will disable the printer. Some companies sell compatible cartridges and reset the chip counter. But unless you reset the chip, even tho the cartridge is full of ink, the chip still disables the printer.
Feb 26, 2011 | Office Equipment & Supplies
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The black is not printing but the cartridge is full
Are you sure that you removed the protective film cover from the terminals of the cartridge before plugging it in?
Also make sure it is seated firmly in it's carriage.
If you have an ink level indicator with your printer's software, and it shows the cartridge to be full, then there might be a problem with your drivers. I would re-install them.
If the indicator shows empty, then the protective film just might be on there.
Lyle
May 03, 2010 | Canon BubbleJet i560 InkJet Printer
I refilled the color cartridge. The light that indicates lack of ink didn?t stop blinking. After a couple of prints, the second light for black ink also started blinking and now the printer doesn?t print...
You can try to press & hold the stop/reset button for 3-5 seconds.
If this still do not clear.
Again try to press & hold the stop/reset button for 3-5 seconds
If the stop/reset button does not work
You may try pressing the color button
Mar 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Waiste cartridge Canon PIXMA MP150
try this to reset your printer.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jun 29, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP460 cartridge error
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Lets hope for the best!
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
Canon PIXMA  iP6310D InkJet Photo Printer Logo
128 people viewed this question
Clive
Clive
old marine
old marine
Ekse
