Question about Mitsubishi WS-65611 65" Rear Projection Television
Picture has purple and green lines and distorted
  • Anonymous Nov 21, 2008
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
2 Suggested Answers
  • 87 Answers
SOURCE: Distorted image, lines, convergence?
If the pip is fine then the digital board is bad. Have it replaced by an authorized Samsung service center as the hex settings have to be copied from the dmd to the new digital board
Posted on Jan 03, 2008
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Screen is distorted with purple and green kind
your crts have gone bad.remove the front
cover and tap on the kneck of the red and green crt.if you see a change.crts are defective.
Jul 29, 2009 | Televison & Video
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Jan 02, 2008 | Samsung HL-R4667W Rear Projection...
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Dvd playback
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Oct 07, 2007 | Bose 3·2·1 Entertainment System...
Mitsubishi WS-65611 65" Rear Projection Television Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
