Question about Canon Rebel XT / EOS 350D Digital Camera
Canon digital camera will not focus
It will not focus clearly in either autofocus nor manual focus mode. It does not matter which lens I have on it.
    Problem Solver:
  • 7 Answers
Check your diopter adjustment. It should be a small wheel on the upper right of the viewfinder. It is designed so that people who normally wear eyeglasses can use the viewfinder without their glasses, but it can occasionally get bumped. If the diopter adjustment is way off, it is like looking through someone else's eyeglasses!
Posted on Mar 18, 2008
Canon Ef_S 18-55mm f/3.5-5.6 Lens won't focus in manual or auto mode
If the camera is used you may have a problem with the seller. Before jumping into conclusions however read your manual for your solution or simply search youtube for a help video. Hopefully this helped.
Feb 14, 2014 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
Oct 04, 2008 | Cameras
How do you shut off auto focus on camera?
The focus mode selector switch is on the front of the camera, just below the lens release button. Switch it to the "M" position for manual focus, "AF" for autofocus.
Jun 02, 2012 | Nikon D80 Digital Camera with 18-135mm...
My canon eos 300d will not lock onto autofocus, no matter which lens I use. Consequently, cannot take fotos using "A/F". (Works ok on Manual Focus) Help!
Clean the contacts on the camera body (and the lens, too) where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 12, 2011 | Canon Digital Rebel / EOS-300D Digital...
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
Will polaroid 52mm lens filters fit my panasonic fz45 camera
Your FZ45 accepts 52mm filters. You can use any 52mm filters you wish on this lens.
There are two types of polarizing filters: linear and circular. The linear polarizing filters are for film cameras and *some* digital cameras. Circular polarizing filters are needed by many digital cameras because the linear polarizing filter types interfere with the autofocus programs. If you shoot in manual focus modes only, it won't matter which you buy. If you do use autofocus, you ought to try the linear before buying - otherwise, purchase the circular polarizer.
I hope this helps! If it did, please rate my reply "4 thumbs up". Thanks!
Aug 01, 2011 | Cameras
Canon 7D -I have my setting on one shot - in any mode.- Lens: Canon 17-85mm. The autofocus jumps back and forth no matter where I focus at.
it means the lens is about to die.
i get same problem with my nikon 18-55 mm lens. the solution for my problem was that i shift from autofocus to manual focus on the llens and then back to autofucus. the lens works fine for me then :P
u can try the same thing.
Mar 02, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I have a nikon d-40 is there a seeting on it that well let the cameras lens focus when you push the button half way down. I took picture but I had to manual focus I don't know if it the lens or this camera...
Any of the autofocus settings will attempt to focus when the shutter is pressed halfway. What lens are you using? If it doesn't have an internal focus meter, then the D40 won't autofocus with it no matter what. If it does have an internal motor, then check to make sure the lens is set on autofocus.
Check Custom Setting 12. If it's set on AF-On then the shutter button won't focus.
If this doesn't fix it, specify the lens and any other details.
Oct 09, 2009 | Nikon D40x Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Autofocus off
Is this when you are trying to focus on something close up? If so you want to go into Portrait mode (turn dial to little head) then hit down arrow on the wheel once to MF mode (manual focus), then use the left and right arrow to focus specific inches or cm.
May 31, 2008 | Canon PowerShot A630 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
239 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
