Question about Polaroid FLM-2011 Television
Wii hd componet cables
I have recently bought the hd componet cables for my wii and when i play there is a black box around the game. When i was using the regular cables the box was not there. I can not figure out how to get rid of it. Any suggestions
  • 29 Answers
Sounds like the screen size on the tv and wii needs to be adjusted. look in the wii settings to adjust that and also see if there is a output resolution that you can change to tell the wii that you're using component. component uses 480i-1080i resolution so there shouldn't be much that you have to change.
Posted on Mar 17, 2008
SOURCE:
Can i use a normal over the counter HDMI cord or is there a "special" Wii HDMI?
Hi, the Wii does not strictly have an HDMI connection but the closest thing to it is a Component cable. This has 5 connections and is as close to HD as you can get without a full HD connection. Make sure your TV has component connections on it as well if you do purchase one. They can be bought for around £5 off of places like ebay.
Hope this helps
Dec 06, 2010 | Nintendo Wii Console
We bought a new samsung 32" flat screen TV. Our HD cable box is connected to the tv using the red/yellow/white cables. Is there an alternative way to connect my Wii without unplugging the HD box...
You'll need to purchase an HDMI cable and use that to connect your hd box to your tv. Your tv should have several HDMI connections on the back to facilitate the hookup and you will not have a true HD picture without that cable. You can buy this cable from the same place you bought your tv or www amazon.com as well as many other electronics supply stores, hardware stores, or places like Kmart, Walmart, Bimart, etc. You can also buy a multi port Rh connector box that you can run multiple components through and just push the corresponding button for the component you wish to operate.
Hope this helps and please rate my solution!!
Nov 27, 2010 | Nintendo Video Game Consoles & Games
Having trouble with the colors on my WIi, everything seems yellow and there is no red anywhere
I just wanted to add that I recently bought a WII and I have the exact same problem. I have a Samsung HD TV and I bought the additional HD cable that has the multiple jacks (i.e. green, blue etc.) I will post if I find a specific answer to the probem.
Dec 24, 2009 | Nintendo Wii Console
Dear Sir / Madam, I bought my Wii in the UK, however we have recently emigrated to Canada and we brought the Wii with us. I have bought the correct power lead and the Wii starts up as usual. The program...
There may be multiple problems with your nintendo wii if there is no picture showing your AV cable may be broke i would buy a new one if thats not it return it buy a AV cable somewhere where there is a loose return policy if this doesnt work i believe UK and Canadian electric outlets are different. And yes if none of these solutions help Canadian games can be played on a UK console. I hope this helps your problem
Dec 23, 2009 | Nintendo Wii Console
I just bought a new plasma tv. I cannot seem to
You Plasma TV is probably an HDTV, which means you need to change the settings on your Wii to HD. Just go to the Wii menu and modify the TV settings. If you don't want to do that, make sure you connect your RCA cables to the non-HD slots on your TV so that the yellow RCA cable is in the yellow slot and not the green HD slot.
Dec 17, 2009 | Nintendo Wii Console
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Screen Jumping
Try and adjust your screen frequency in the wii system settings.
Mar 26, 2008 | Nintendo Wii Console
Hook up
hi, im using a HDTV with my wii, but im just using the standard cables ie, wii - skart connection , one to wii sensor, and one to mains plug from wii,
and works fine..
All the best
john
Jan 02, 2008 | Nintendo Wii Console
Disk wont load.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
169
Nov 30, 2007 | Nintendo Wii Console
Polaroid FLM-2011 Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
