Question about SanDisk Sansa e200 MP3 Player
Charging an MP3
Expert,
Should I turn off the power when I charge?
  • 3 Answers
It doesnt really matter because it will turn back on and say connected
Posted on Mar 24, 2008
SOURCE:
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
No power
Make sure that the battery is fully changed. Now, you need to test it to see if there's a problem with the battery or with the power switch.
Charge the player and turn it on while charging. If the player turns on while charging, then there could be a problem with either the battery or the wiring inside.
If the player will not turn on even if it's charging, then it could be the power button or some other components inside the player.
Hope this helps and have a great day!
Aug 12, 2009 | Sony Walkman Video NWZS615F MP3 Player
"insufficient power" while charging
well there is some problem with ur power supplyand it needs physical assistance get it checked by an expert. nad please read the menual.
Jul 26, 2009 | Transcend T.sonic 850 Digital Media Player
Samsung mp3 mini wont turn on.
you should be charging your mp3 using the cable provided by the manfacturer.check for any defects in that cable (like wear or tear).try a different cable from someone else(friends) and check if its charging..if it does so then buy a new cable separately..
May 22, 2009 | Samsung YP-Z5 MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
My creative zen won't charge or turn on
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed.Cupthe player in your hands to check that the blue power LED behindthePlay/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Ifthe player does not indicate a charge, or will not power on afteratleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to takeadvantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Won't Charge
On some systems, the usb does not supply enough power for battery charging, so it briefly comes on, then goes off. Also there are power adapters with a USB plug on them for charging things that use the USB for power. You may have to end up buying one. Though they are very usefull now that more and more devices use the USB for battery charging power.
May 24, 2008 | Insignia Pilot MP3 Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
SanDisk Sansa e200 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
