Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Hitachi 51F510 My television turns red how do i fix it?
Optic engine is bad
Posted on Mar 26, 2008
SOURCE:
I have a Hitachi F5F110. The red/pink is way out of balance on this TV. I've done everything I can do to try and fix it, including the magic focus built in on the computer and I've also turned...
51F510 SHOULD use two STK392-150 CONVERGENCE integrated circuits. Too much to explain here but I am available on the site as a pay question attention: SD TECH.
sd tech
Sep 19, 2011 | Hitachi 51F510 51" Rear Projection...
My Hitachi 51f510 projection tv just started to have a problem with the color. It appears that the tint is red/pink and I have no control over it.
For me to help you (I think I know what is wrong and it is fairly simple to correct) I need to ASK you something.
If you turn the color all the way to zero and go to a channel that is in black and white, what color is the screen?
If it is red or redish a simple adjustment will correct this problem.
Is the picture with color down to zero on a black and white channel (old movies) red looking?
Before you rate this information, let me know what you find. I am in California and will be available for a while.
SD TECH
Jul 15, 2011 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 has no picture. a RED X is visible after a pair of 'gears' in the middle of the screen appear during a long boot recovery attempt which fails ending in the red X
replace middle power supply broad that has 2 regulators, send to PTS for repair.Also check transistor mounted next to flyback transformer it maybe shorted too!
Dec 01, 2010 | Hitachi 51F510 51" Rear Projection...
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi TV proble
Here's a high-voltage problem that needs to be addressed...accordianman
Jan 12, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 HDTV Hit by lightning
The steps that need to be taken on fixing this set start with the standby voltage requirement. Is it there? next is the low voltage loop from the transformer, also a requirement for the set to come on. ...accordianman
Nov 19, 2007 | Hitachi 51F510 51" Rear Projection...
Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
