Question about Honeywell HZ-710 Oil Filled Radiator Heater
Oil filled heater wont stay on
When i turn my heater on an f appears and only stays on for a few seconds then shuts off .
  • 3 more comments
  • MaxineF Oct 02, 2008
    i have the same prob..and i own 3 (none work properly). Called Kaz ...they say they have never had the prob reported to them before, and I could send them back for repair! SO DISGUSTED!
  • lions_fan253 Oct 05, 2008
    mine stays on very rarely. sometimes it will kick off 10-20x in a row . the ambient light never comes on anymore. more info on the returning of one by hz-710 owner
  • Anonymous Nov 13, 2008
    ditto..so agrivateing ... and im so not into trying to ship something off esp weighing so much. a qicker fix is go get a new one... you get heat ..that way
  • nfannin Nov 16, 2008
    JUST GOT HEATER OUT OF CLOSET. IS DOING THE SAME THING. WON'T STAY ON. JUST KEEPS KICKING OFF AFTER TURNING ON. SUCH A SHAME. ONLY 2 YEARS OLD. LIKE SOME OF THE OTHERS, WOULD COST A FORTUNE TO SHIP BACK PLUS THE $10 DOLLARS THAT YOU NEED TO SEND WITH IT. HAS ANYONE SHIPPED ONE? HOW MUCH DID IT COST?
  • Anonymous Dec 22, 2008
    still having same problem with heater . an f comes on for a few seconds then it kicks off. it wont let me even turn the temperture down before it kicks off
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Posted on Dec 18, 2008
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Started up my acura tl 2000 and started to hear knocking and shut off
Check oil level and oil pump. Oil pump light should turn off after a few seconds after start up. If light stays on for more then 3 second shut off and do not drive or run motor.
Jan 12, 2010 | 2000 Acura TL
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
Heater will fire but wont stay lit.
I assume that you are referring to a natural gas forced air furnace. If so you just described the symptoms of a dirty flame sensor. Remove the sensor with a 1/4" nutdriver. clean the flame sensor with a small piece of fine grit sandpaper or emery cloth. replace the sensor and turn the furnace back on.
Good luck.....
Apr 11, 2009 | Heating & Cooling
Heater on,off,on,off,on,off.......
That is a bad wall thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 24, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
The heater will not ignite properly
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Feb 28, 2008 | Cozy (W352E) Heater
Honeywell HZ-710 Oil Filled Radiator Heater Logo
476 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
