Question about Whirlpool Duet GHW9150P Front Load Washer
Rinse cycle softener will not empty during the rinse cycle how do I get the softener to go into the machine at the correct time during the rinse cycle?
    President:
  • Whirlpool Master
  • 2,651 Answers
Di you try to remove the drawer completely and check for a blockage under he dispenser itself.(sometimes te fabric softener can get kinda gunky.. if you extend the dispenser you see a little black tab in top left corner, push it down and dispenser will release, just in case you didnt know that
Posted on Mar 17, 2008
SOURCE:
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
G155
You have to do it manually. See below from manual:
Sep 09, 2012 | Hotpoint Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Fabric softener dispenser will not empty during rinse cycle (or anytime)
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Sep 17, 2010 | Washing Machines
Fabric softener doesn't empty during wash. I use he softener, and don't overfill the basin. The washing machine completes the cycle, but the softener doesn't empty.
my son had this same problem and when we took the dispenser out and checked the hoses they were clogged with semi hardened fabric softener that didn't pass through. they always used a warm wash with a cold rinse and since i told them to use a hot water wash with a cold rinse at least once a month they have not had a problem. hope this helps.
Oct 14, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Jun 05, 2008 | LG WM2688H Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Feb 14, 2007 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
258 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
