Question about LG WM-2277HW Front Load Washer
Washer My washer door is locked and clothes are still in it and it will not spin. HOw can I getr it open???
    President:
  • 1,294 Answers
Check the filter located at the bottom left hand corner. There is a door that you can open and pull out the filter. Be prepared for a lot of water. Your door won't open if there is water in the tub
Posted on Mar 17, 2008
SOURCE:
Unlocking a may tag door washer
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
Jun 02, 2016 | Maytag MAH6700AWW Neptune Front-Load...
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
100 series clothes washer not spinning
I don't see a question but you may find help at the link below.
If you need to buy parts or diagrams try searspartsdirect.com
Have your model number ready.
maytag washer won spin YouTube
Jul 24, 2014 | Maytag Clothes Washer Door Lock Switch...
The washer door is locked and will not open
Problem with Maytag MHWE450WW front load Maytag washer. The washer door is locked and will not open. I tried several suggestions in the manual, but none work. Please help!!! My email address is
[email protected] and my name is Antoinette Roy
Oct 10, 2012 | Maytag EPIC MFW9700S Front Load Washer
Machine only hums, will not spin, wash nor will the door open.
  • It sounds like the motor is spinning, but the drum is not spinning. This usually means the belt has broken, or come off of the pulley.
  • Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
  • Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
  • Broken wires at one of the out off balance switches or a bad switch itself.
  • A fairly common trouble maker has been a burnt diode on the main control board.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
  1. Remove the bezel from the soap/bleach/fabric softener dispenser.
  2. Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle works with nothing in the drum but not with clothes in
if your washer does everything but spin, it is a door lock problem. Note: The door does lock, but does not send the correct signal allowing the washer to spin!!
Dec 31, 2010 | Candy CN146 Front Load Washer
Door is locking but machine will not execute spin cycle
My washer is draining the tub but it's not spinning .Would this be minor or should i buy a new one.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
LG WM-2277HW Front Load Washer Logo
107 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
